follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 77
Search took
0.27
seconds.
Search:
Posts Made By:
projek_01
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
03-06-2024, 03:21 PM
2,509
FR-S 10 Series Registry
699,223
Posted By
projek_01
I made my own PCB to get my EL dash lights...
I made my own PCB to get my EL dash lights working again. The fuses behind the radio were still good so I narrowed it down to a burnt out controller. I have enough parts to make one more. Does anyone...
Forum:
Forced Induction
01-11-2023, 10:37 AM
4,306
Kraftwerks Supercharger Owners Thread
1,341,628
Posted By
projek_01
^not sure if you already fixed it but the threads...
^not sure if you already fixed it but the threads on that part look pretty messed up. That might be the reason why it backs out under load. The longer bolt might be bottoming out and not holding the...
Forum:
Canada Classifieds
05-03-2022, 09:13 AM
43
Why I will never be purchasing from FT86 Motorsports again
5,098
Posted By
projek_01
I agree that the language/tone used was pretty...
I agree that the language/tone used was pretty unprofessional.
I don't think they are being unreasonable for declining your warranty request. You can't expect anything more than an "eBay" grade...
Forum:
Electronics | Audio | NAV | Infotainment
08-27-2021, 12:57 PM
18
Adding Steering Wheel Controls to my 2013
9,540
Posted By
projek_01
The AliExpress SWC buttons work using a...
The AliExpress SWC buttons work using a resistance ladder. Each button correlates to a particular resistance between Key1/Key2 and ground.
An Arduino was utilized to read the resistance by using a...
Forum:
08-09-2021, 12:37 PM
18
9,540
Posted By
projek_01
Yeah, just search wireless steering wheel control...
Yeah, just search wireless steering wheel control on AliExpress. They are designed to work with chinese android head units but there are ways to adapt the signal. I have started this for JVC/Kenwood...
Forum:
08-06-2021, 04:06 PM
18
9,540
Posted By
projek_01
After endless failed prints, weak tabs, tweaks...
After endless failed prints, weak tabs, tweaks and different brands of filament. I think I am finally content enough with this one.
Forum:
06-20-2021, 06:51 PM
18
9,540
Posted By
projek_01
Made a few steps forward in this project. I...
I have the prototype sketched up and ready to print once I have the wireless buttons. ...
Forum:
Forced Induction
08-19-2020, 01:47 PM
4,306
1,341,628
Posted By
projek_01
D-VO Seems like your best bet is to use a dial...
D-VO
Seems like your best bet is to use a dial indicator with a magnetic stand to measure runout. Either one of your idlers, supercharger pulley or crank pulleys can cause the belt to change tension...
Forum:
Forced Induction
05-14-2019, 01:02 PM
63
Opened up my Rotrex today. Here are my thoughts.
20,830
Posted By
projek_01
Built this filter to catch any exploding bits in...
Built this filter to catch any exploding bits in the event my rebuild was a bust.
https://img.photobucket.com/albums/v306/Projek_01/edited-image_zps12qxys1t.png
Forum:
Forced Induction
05-03-2019, 03:21 PM
63
20,830
Posted By
projek_01
The blower has been installed and idled without...
The blower has been installed and idled without any issues. I hooked up some temporary clear PVC tubing to the oil return line to make sure there was oil flowing before I let the engine fire up. I...
Forum:
Forced Induction
05-01-2019, 10:26 PM
63
20,830
Posted By
projek_01
Fair enough, you have a stronger educational...
Fair enough, you have a stronger educational background (engineering) in this stuff than I do. Saying I have no idea about the tolerances and material specs however is incorrect and is very naive....
Forum:
Forced Induction
05-01-2019, 06:26 PM
63
20,830
Posted By
projek_01
Wow, what makes you so sure that my unit will...
Wow, what makes you so sure that my unit will never work or be reliable again? Do you have a mechanical or engineering background to explain why it wouldn't?
I'm glad your unit is good and...
Forum:
Forced Induction
05-01-2019, 11:56 AM
63
20,830
Posted By
projek_01
The theory of the inner workings is nothing...
The theory of the inner workings is nothing revolutionary. They basically turned a planetary gear set into rollers by making the "ring gear" super tight. Effectively making everything interference...
Forum:
Forced Induction
04-29-2019, 06:14 PM
63
20,830
Posted By
projek_01
I finally got to replacing every bearing with NSK...
I finally got to replacing every bearing with NSK bearings which Rotrex also uses from the factory. Luckly, all but one of the bearings I purchased locally were made in Japan. Not sure if that makes...
Forum:
Forced Induction
04-22-2019, 07:34 PM
63
20,830
Posted By
projek_01
The shaft is finally done and according to my...
The shaft is finally done and according to my Mitutoyo digital caliper, it is the correct size.
https://oimg.photobucket.com/albums/v306/Projek_01/IMG_20190422_172057_zpszunpzt5o.jpg
top: new...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
04-16-2019, 10:01 AM
16
how much POG oil to put into AC after condenser replacement
4,873
Posted By
projek_01
They should not sell these refill kits because...
They should not sell these refill kits because people usually do not use them correctly. If you need to refill your A/C, you have a leak in your system. That means, properly evacuating the system...
Forum:
Forced Induction
04-09-2019, 08:52 PM
63
20,830
Posted By
projek_01
I received a call last week from the turbo shop...
I received a call last week from the turbo shop saying that the shaft broke when they were tightening the nut on the compressor wheel before balancing.
Normally, I'd be outraged and demand them...
Forum:
Forced Induction
03-27-2019, 09:58 AM
63
20,830
Posted By
projek_01
Some small updates today. Custom output shaft oil...
Some small updates today. Custom output shaft oil seal is on it's way. Made these 3D printed parts to hold the shaft in a vise so I can press the compressor back on. Going to pay some money to get...
Forum:
Forced Induction
03-26-2019, 11:14 AM
63
20,830
Posted By
projek_01
I have concluded that the 6203 and 6003 bearing...
I have concluded that the 6203 and 6003 bearing on my input side were likely causing my issues. There was some noticeable roughness just from spinning them in my hand.
Rotrex chose to use normal...
Forum:
Forced Induction
03-06-2019, 08:33 PM
63
20,830
Posted By
projek_01
I made some new progress today. First, I greased...
I made some new progress today. First, I greased the crap out of the rollers. I wanted to minimize the force I would need to press them out....
Forum:
Forced Induction
03-05-2019, 04:30 PM
63
20,830
Posted By
projek_01
Haha good eye! I'm a chemist by training working...
Haha good eye! I'm a chemist by training working on the Rotrex while I'm waiting for lab tests to finish.
Forum:
Forced Induction
03-04-2019, 09:15 PM
63
20,830
Posted By
projek_01
*Disclaimer - This is by no means a DIY or tutorial on how to rebuild a Rotrex. I'm no expert and may or not be doing things correctly.*
Growing up, one of my dream cars was the Honda S2000. So...
Forum:
10-28-2016, 03:16 PM
26
My alternator dying?
11,735
Posted By
projek_01
If your voltage/charging system is intermittently...
If your voltage/charging system is intermittently charging, it could be worn alternator brushes. If you have over 60k miles on it, it could be a possible. Our ECUs also control the voltage regulator...
Forum:
Issues | Warranty | Recalls / TSB
08-02-2016, 01:12 PM
35
2017 Toyota 86..More reliable?
17,216
Posted By
projek_01
It will probably be a bit better but I think the...
It will probably be a bit better but I think the things you listed are blown out of proportion from being on this forum.
The engine problems were mostly fixed within the first year.
The tail...
Forum:
04-19-2016, 12:14 AM
26
Jerk bird attacking 86
6,418
Posted By
projek_01
How did you stand there and watch it peck the...
How did you stand there and watch it peck the paint? I would have chased it away and got some weapons for the next time.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-07-2016, 05:02 PM
21
Understeering with Grimmspeed front bar
3,315
Posted By
projek_01
I'm not expert but I find that keeping my foot on...
I'm not expert but I find that keeping my foot on the gas early on in corner helps with the under steer dramatically. Quite different to drive compared to a FWD Celica I used to drive.
Forum:
02-03-2016, 10:34 AM
543
Toyota to scrap Scion brand, but FR-S will become a Toyota!
199,720
Posted By
projek_01
I will now handle my Scion 10 Series book with...
I will now handle my Scion 10 Series book with cotton gloves. It is now a piece of automotive history.
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
07-31-2015, 11:30 AM
9
Taillights for 10 Series
2,904
Posted By
projek_01
I was confused looking at your title lol. I...
I painted my own set of "Grazio & Co" tails. Took like a full day to get the masking lines taped up. I like how they look.
Forum:
User/Vendor/Sponsor Reviews, Feedback, Comments
07-23-2015, 03:44 PM
0
Kraftwerks Review
1,433
Posted By
projek_01
Kraftwerks Review
I would like to post my positive experience with Kraftwerks. Whenever I had a any issues, they were more than happy to make things perfect again.
In my first experience, my supercharger came...
Forum:
Off-Topic Lounge [WARNING: NO POLITICS]
05-28-2015, 05:04 PM
55
Source of petroleum? Dinosaurs? - NOT!
14,212
Posted By
projek_01
Stu, you are taking this debate to a whole...
Stu, you are taking this debate to a whole different level. Yes, it is possible that hydrocarbons could have been made without organisms. I am just very skeptical of how the heavier/complex stuff...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Site Announcements / Questions / Issues
03:44 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
