follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 56
Search took
0.32
seconds.
Search:
Posts Made By:
scion fr-s
Forum:
Engine, Exhaust, Transmission
07-07-2023, 11:07 AM
9
RPM Fluctuation At Idle
835
Posted By
bcj
Starting in '17, the charging system went to...
Starting in '17, the charging system went to intermittent battery charging.
The ECU monitors use and will turn the alternator on and off depending on current need.
That will put more or less load...
Forum:
07-07-2023, 08:48 AM
9
835
Posted By
Grady
It’s a BRZ thing, you can not fix an engineering...
It’s a BRZ thing, you can not fix an engineering mistake.
Forum:
01-04-2023, 08:17 AM
18
Is alternator output load dependant ???
2,890
Posted By
Assuming they still use the updated system from...
Assuming they still use the updated system from '17.
It would be concerning if it DIDN'T fluctuate.
Forum:
Issues | Warranty | Recalls / TSB
10-30-2022, 01:11 AM
12
Damaged Thermostat?
4,134
Posted By
malkduds
Yeah no such problem, like others have alluded...
Yeah no such problem, like others have alluded to, the gauge for coolant is a rough estimate of a safe range (even though the needle might not move).
It can go up to 110C before fans kick in and...
Forum:
06-30-2022, 12:51 AM
3
Splitter Connector to run FF and O2 sensor
548
Posted By
^^ This ^^ Need an input channel when there are...
^^ This ^^ Need an input channel when there are no extras. Repurpose the least important one.
Forum:
06-29-2022, 10:07 PM
3
548
Posted By
NoHaveMSG
I don't think it will work. I believe using the...
I don't think it will work. I believe using the FF kit that connects to the secondary o2 and a corresponding tune hijacks the A/F compensation table associated with that sensor for the ethanol...
Forum:
BRZ First-Gen (2012+) -- General Topics
06-24-2022, 09:39 AM
1
Passenger Rear Wheel Liner
781
Posted By
Grady
Looks like the right part to me.
Forum:
05-16-2021, 10:45 AM
36
Has FedEx always been this bad?
4,725
Posted By
thomasmryan
My UPS driver will put things inside the garage...
My UPS driver will put things inside the garage which is nice. USPS is quite inefficient with their scanning/software but the delivery peeps go out of their way to keep things dry.
Not a fan of...
Forum:
05-16-2021, 01:01 AM
12
2017 86 Header Compatible with 2013 FRS?
2,642
Posted By
Silencio, old man. Stock header doesn't have...
Silencio, old man. Stock header doesn't have anything to do with "loud.":bs:
He's right. I have no idea.
Forum:
05-16-2021, 12:36 AM
12
2,642
Posted By
DarkSunrise
No issues. I’m using a revised 2017 manifold and...
No issues. I’m using a revised 2017 manifold and it fits the same as my 2013. Sounds better too in the midrange due to the revised (more EL) layout. Bolt it on and enjoy.
Forum:
05-16-2021, 12:17 AM
36
4,725
Posted By
BrahmaBull1990
Package came today - finally!
Forum:
05-16-2021, 12:16 AM
12
2,642
Posted By
I'll defer to Tcoat. Ol Ultramaroon don't...
Ol Ultramaroon don't know nutten bout loud exhausts - so, Bubba tells me - :iono:
Forum:
05-14-2021, 02:01 AM
17
Tips for a Newbie?
2,259
Posted By
Milk crates ain't come to Bubba's world yet, but...
Milk crates ain't come to Bubba's world yet, but he does have old milk cans that he could make do.
:thumbsup:
Forum:
05-06-2021, 07:03 AM
18
Electric water pump
3,478
Posted By
Ashikabi
I don't believe that is correct. Your crank...
I don't believe that is correct. Your crank directly drives the water pump, which means it uses horsepower to do it. Going electric would free that horsepower. Up to the point that your alternator...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
05-06-2021, 02:08 AM
22
Michelin PS4: 215 vs 225 for 17x8 wheel
9,499
Posted By
churchx
Difference of gearing of 1.4% for 215 vs 225?...
Difference of gearing of 1.4% for 215 vs 225? Probably won't be noticeable by butt dyno. How harsh ride is or how sharp steering is and how much one paid for tires, probably will be more noticeable :)
Forum:
05-06-2021, 01:57 AM
22
STI Exhaust Part Number
4,928
Posted By
nikitopo
Yes I agree. These ones have a dual structure...
Yes I agree. These ones have a dual structure with a tubular pre-silencer and main silencer arranged in parallel front to back. It is a quite unique design and build quality is similar to jewelry. I...
Forum:
05-05-2021, 10:38 PM
18
Electric water pump
3,478
Posted By
Don't encourage him - that's a dumb idea. ...
Hell, I can remember when water cooled cars didn't have water pumps - :iono:
Forum:
05-05-2021, 09:48 PM
18
Electric water pump
3,478
Posted By
Very little. :slap: Get back in the...
Very little.
:slap:
Get back in the box! - ;)
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
04-28-2021, 08:00 AM
4
Front Sway Bar Mounting Location
1,011
Posted By
BigTuna
Right - 50515CA009P Left - 50515CA109P
Right - 50515CA009P
Left - 50515CA109P
Forum:
04-09-2021, 07:52 PM
6
Clutch suggestion
926
Posted By
jmai
310 wheel horsepower, and stock clutch can’t...
310 wheel horsepower, and stock clutch can’t really handle the added power/torque without slipping
Forum:
03-06-2021, 03:38 PM
2
PCV Valve Question
1,235
Posted By
Although it's Bubba's day off, he did respond,...
Although it's Bubba's day off, he did respond, although he was bad hung over - :cheers:
He suggested you soak the stuck PCV in warm coal oil for an hour, then turn the heat up to high and boil for...
Forum:
03-05-2021, 04:38 PM
24
Advice on Used BRZ Hunting
3,021
Posted By
AnalogMan
I couldn't agree more with both of these...
I couldn't agree more with both of these suggestions. I've been driving for nearly 50 years (yeah, half a century, makes me old, but also experienced)(ugly too, but that's not important). I've owned...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
02-06-2021, 10:40 AM
10
I need help with activating FOG Lights
1,384
Posted By
Those are your daylight running lights. They will...
Those are your daylight running lights. They will always go off when you turn the headlights on. If headlights are off they will also go off if the car is in park (AT) or the parking brake is pulled...
Forum:
Northern California
12-18-2020, 06:45 AM
2
FRS/BRZ
859
Posted By
DarkPira7e
https://www.ft86club.com/forums/forumdisplay.php?f...
https://www.ft86club.com/forums/forumdisplay.php?f=69
This section is home to any vehicle for sale by a member of this forum. :)
Forum:
07-14-2020, 08:11 PM
25
Can anyone get STI motor mounts right now?
3,482
Posted By
86TOYO2k17
Driveshaft shop
Driveshaft shop
Forum:
07-14-2020, 07:50 PM
25
3,482
Posted By
86TOYO2k17
I got sti mounts, Whiteline trans collar,...
I got sti mounts, Whiteline trans collar, whiteline rear diff collars, and Carbon fiber driveshaft. Didn’t notice any NVH increase.
Oem is a 1
STI is a 2
Perrin 3
Cusco 4
Solid 5
Only...
Forum:
03-19-2020, 10:59 PM
39
Seat Bolt Trouble
6,723
Posted By
There are a couple things that work together to...
There are a couple things that work together to doom these screws.
1. There's way too little tool area for the diameter of that clamping surface.
2. Black zinc coating practically welds itself to...
Forum:
03-19-2020, 01:42 PM
39
Seat Bolt Trouble
6,723
Posted By
Westen86
It could have been worse. This was my experience....
https://i.imgur.com/WhsZJDN.jpg
Forum:
03-18-2020, 11:35 PM
39
Seat Bolt Trouble
6,723
Posted By
If you have a dremel and are really patient, you...
If you have a dremel and are really patient, you can grind off the head. The screw itself will easily back out.
I prefer nibbling at stuff with those cutoff wheels.
Forum:
03-18-2020, 11:13 PM
39
Seat Bolt Trouble
6,723
Posted By
new2subaru
Another option is to drill the heads off ...
https://www.ft86club.com/forums/showpost.php?p=3168017&postcount=22
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
05:41 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
