follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
4.71
seconds.
Search:
Posts Made By:
BrahmaBull1990
Forum:
BRZ First-Gen (2012+) -- General Topics
07-14-2022, 01:23 AM
19,883
WHAT DID YOU DO TO YOUR BRZ TODAY?
8,861,702
Posted By
Busybee
Installed Grimmspeed hood struts ...
https://uploads.tapatalk-cdn.com/20220714/1b0a9d6b4ab03dd3562f598f98811778.jpg
Great quality! 15 min job and flush fit. Happy [emoji4]
Sent from my...
Forum:
Engine Swaps
05-05-2022, 03:10 PM
347
Likely the first FA2/4 hybrid incoming
79,258
Posted By
elBarto
The engine is running and has been on the dyno. ...
https://i.postimg.cc/bSPz90hP/EMS-FA20-FA24.jpg (https://postimg.cc/bSPz90hP)
[/URL][URL="https://fb.watch/cPSZ-e5s7F/"]Facebook video of the...
Forum:
04-27-2022, 09:29 AM
19,883
8,861,702
Posted By
Dirty Harry
Installed the Mishimoto inlet tube, cleans the...
Installed the Mishimoto inlet tube, cleans the engine bay up a bit, but the best thing is the driving. Slightly more torque down low and a bit more surge past 4000 rpm, definitely noticeable and not...
Forum:
04-21-2022, 12:20 PM
45
This is simply a joyful car
6,929
Posted By
Sasquachulator
I also must add... And i think this might only...
I also must add...
And i think this might only apply to the 2017+ MT models but....
The engine bay is actually quite pretty with the red intake plenum.
Everything nowadays has a plastic cover...
Forum:
Forced Induction
04-19-2022, 04:56 PM
4,965
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,503,474
Posted By
Decep
That.. seems like a bad idea if that's true....
That.. seems like a bad idea if that's true. Recommending an unoiled K&N filter designed to be used with oil to catch particles is a bush league move
Forum:
Forced Induction
04-19-2022, 12:08 PM
4,965
1,503,474
Posted By
BRZBuzz
Air Filter Information
After reading all the recent posts pertaining to air filter service and/or replacement, I became inquisitive to if I purchased a new air filter if it would be a) manufactured using K&N's dry...
Forum:
04-15-2022, 07:33 PM
19,883
8,861,702
Posted By
Busybee
Started to clean calipers ended up detailing the...
Started to clean calipers ended up detailing the car [emoji16]
https://uploads.tapatalk-cdn.com/20220415/5682782ef0e8ba9b2391a192b8868957.jpg
Forum:
Engine Swaps
04-14-2022, 01:30 AM
472
Irace86.2.0's KPower Turbo K24 Swap
91,799
Posted By
Irace86.2.0
Here are few of the final pulls. This was 9psi....
Here are few of the final pulls. This was 9psi. The ID1050x injectors were maxing out, and this is where I wanted to stop anyways (400whp/300wtq). Shawn thought the graph could be smoother, and he...
Forum:
Forced Induction
04-13-2022, 05:43 PM
4,965
1,503,474
Posted By
Brewster
https://www.knfilters.com/99-0624-filter-cleaner-s...
https://www.knfilters.com/99-0624-filter-cleaner-synthetic-32oz-spray
I don't think K&N's dry filter cleaner is oil based
Forum:
Engine, Exhaust, Transmission
04-06-2022, 10:58 PM
12
Car dies after I give it gas once warm
1,420
Posted By
Grady
Glad you found it! Now go have fun! :burnrubber:
Forum:
04-06-2022, 05:58 PM
12
1,420
Posted By
toughguy39
Hey guys, Yep human factor stroke this time....
Hey guys,
Yep human factor stroke this time. It was a leak at the throttle body. The coupling was pretty loose. It felt tight on the clamp but it wasnt. I also retuned the car with same tune just...
Forum:
Engine Swaps
04-04-2022, 05:15 PM
472
91,799
Posted By
Irace86.2.0
Car is working. :thumbup: Embarrassing error...
Embarrassing error on my part. In my panic to pull a fuse before the battery died (AGM lightweight battery) to stop the car that was stuck in accessories and wouldn't...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
03-30-2022, 09:00 PM
85
10W-50 oil in BRZ?
11,202
Posted By
KillerBMotorsport
On a stock engine, this is a bad idea. Will your...
On a stock engine, this is a bad idea. Will your oil pressure go up, heck yes! But your oil flow will absolutely go down. To run heavy weight oil, the engine needs to be properly built for it. There...
Forum:
03-30-2022, 07:14 PM
19,883
8,861,702
Posted By
Busybee
Finally got the Summers on!
Can’t be happier [emoji4]
https://uploads.tapatalk-cdn.com/20220330/16ba859506217f82a28f169b9f424f09.jpg
Forum:
03-30-2022, 03:30 PM
85
10W-50 oil in BRZ?
11,202
Posted By
lapsio
10W-50 oil in BRZ?
So I dropped my BRZ for regular service after 10k km which is fairly low interval but I'm hammering my BRZ fairly hard and tracking it quite often, so guys at Subaru recommended to check in every 10k...
Forum:
Engine Swaps
03-28-2022, 05:04 PM
472
91,799
Posted By
Irace86.2.0
The flywheel should be here Wednesday. Depending...
The flywheel should be here Wednesday. Depending on the time. I might get things back together Wednesday, but probably completed by Friday at the latest, assuming I don't run into any other snags.
Forum:
03-26-2022, 08:49 AM
19,883
8,861,702
Posted By
Breezio
Put the sticky buns on for the EVO driving school...
Put the sticky buns on for the EVO driving school this weekend.
Forum:
03-25-2022, 04:24 PM
19,883
8,861,702
Posted By
Grady
Track prep day. Brake fluid, oil change,...
Track prep day. Brake fluid, oil change, alignment, tire rotation, general checkout. Since the Evora is sucking up the rack had to do it in the driveway on jacks. Glad it was a nice day out.
Forum:
Forced Induction
03-24-2022, 03:22 PM
4,965
1,503,474
Posted By
B T
Good news, new batch of remote maps supposedly...
Good news, new batch of remote maps supposedly shipped my way today.
Forum:
Engine Swaps
03-24-2022, 01:01 AM
472
91,799
Posted By
Irace86.2.0
Went to the dyno today. It was my first time...
Went to the dyno today. It was my first time operating a car on a dyno. It was a different experience, but fun...up until the moment we started having issues. We were getting some boost drop off, so...
Forum:
Forced Induction
03-21-2022, 10:50 PM
4,965
1,503,474
Posted By
ABQautoxer
Today I finished my SC install along with BT's...
Today I finished my SC install along with BT's remote map kit. No leaks or issues on the test drive datalog so I'm hoping to get a clean bill of health and start turning up the fun in the tune soon.
Forum:
Engine Swaps
03-20-2022, 05:27 PM
101
K24 FRS TA build
18,962
Posted By
hedtrip
Yeah it sucks alot. But she can be rebuilt. ...
Yeah it sucks alot.
It's only been a week & have replaced the Radiator, fans, Rad support, Hammered & rewelded some stuff. Did a rough alignment & she isnt driving half...
Forum:
Forced Induction
03-19-2022, 01:28 PM
4,965
1,503,474
Posted By
tomm.brz
Your tuner is not aware apparently that ZA1JK00C...
Your tuner is not aware apparently that ZA1JK00C tunes , with any racerom patch available in the last 3 years, is EXTREMELY BUGGED
It's pretty obvious on the logs, like the PI% forced to 100% when...
Forum:
Forced Induction
03-17-2022, 09:46 PM
4,965
1,503,474
Posted By
BirdTRD
You should be able to find someone to weld...
You should be able to find someone to weld stainless steel relatively cheap. I've had to have my Tomei headers repaired (bought new) and a used Berk front pipe fixed as well. Local guy charged my $20...
Forum:
Forced Induction
03-17-2022, 05:40 PM
4,965
1,503,474
Posted By
FrickingReallySlow
Curious how did you see it's a cracked weld?...
Curious how did you see it's a cracked weld? since you couldn't jack up the car to take off the undertray.
I experienced something like this as well over last summer for a couple of days when it...
Forum:
03-17-2022, 03:14 PM
29
Gen2 Transmission swap?
6,406
Posted By
At this point there are not enough miles on them...
At this point there are not enough miles on them to even decide if they are "more reliable" anyway. They could turn out to be crap.
Forum:
Forced Induction
03-16-2022, 07:15 PM
4,965
1,503,474
Posted By
CSG Mike
Are you on the stock tune?
Forum:
Forced Induction
03-15-2022, 10:09 AM
4,965
1,503,474
Posted By
Auto_egr
Ignore my past comment about unmetered air going...
Ignore my past comment about unmetered air going into the engine, I misread your update since you mentioned it's running rich. If you're getting negative LTFT it's pulling fuel for some reason. Not...
Forum:
Off-Topic Lounge [WARNING: NO POLITICS]
03-15-2022, 07:47 AM
3,237
Poll:
Tcoat's Lunch? [OFFICIAL THREAD] GONE SEXUAL!!!
470,758
Posted By
MomHawk made me a homemade chicken pot pie over...
MomHawk made me a homemade chicken pot pie over the weekend for my Birthday. My lack of photography skills does not do it justice.
Forum:
Forced Induction
03-15-2022, 05:16 AM
4,965
1,503,474
Posted By
CSG Mike
It depends on WHEN youre getting the trim. When...
It depends on WHEN youre getting the trim. When does the trim appear and when does it go away?
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Site Announcements / Questions / Issues
01:13 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
