Tire Fitment 18x9.5+35
Hey guys, I just got my wheels in they are 18x9.5 with an offset of +35. I was looking at running 245/35/18 in the front and 255/35/18 on the rear. I have a 1 inch drop. Will I experience any rubbing with this setup? If anyone is running this setup and can give some input, it would be greatly appreciated. I'd like to get the wheels as flush as possible but don't want to be rubbing. Thank you.
Are you running springs or coils?
And what is your alignment specs? https://www.ft86motorsports.com/wheelitfit/ |
Depending on your alignment, you may rub on the front fender or the front spring perch. You might be able to fit 245s on those wheels, but it will require some fiddling. Regardless, I would suggest two things: (1) Don't stagger your tire sizes. There's no reason to do so. The car was designed for a square setup. Staggering also means you can't rotate your tires front-to-back. (2) Ideally, you should be running a 255 or 265 on those wheels. 245 won't be dangerous or anything, but it's not ideal. But you'll have problems fitting 255 or 265s, so either get coils and add -2.5 front camber, or get different wheels that fit better on stock dampers. |
I have the same set up, but I switched to coils. Also, you'll have some pretty bad poke in the front without any negative camber adjustment, just FYI on that, it won't be "flush" per se. |
I concur.
Hi there.
Do not stagger your tire sizes. If your wheels are all 18x9.5 than you need to run the same size tire all around or else you will run into issues with oversteer/understeer. An 18x9.5 should run a 255/35/18 or larger tire. Anything less will not be ideal, UNLESS you specifically want the stretched tire look, or a stanced out car. If you are doing grip driving, go with a 255 or larger. I run a 18x9.5 +40 with a 265/35/18 and it did/does rub if you do not apply enough camber. The fact that your wheels are a +35 means they will stick out farther than mine do, so I could imagine they will rub on the fenders unless you add a decent amount of camber. However, you only have a 1 inch drop, which is not much, so I don't think you would have any rubbing issues. You should check out the meaty tire thread! There are lots of people running the same setup as you. |
Been reading on the forums about tire size, I am currently running 18x9.5 with 255/35 and I am on coils. I experience rub only sometimes, is it because the tire size? |
I needed 5mm spacers on the front for 17x9 35 offset with 255 tires. ymmv.
I run either a 3mm or a 5mm spacer up front to keep the tire out of the coil on 17x9.5 +45 depending on which 255 I am running at the time.
ymmv also |
It could be a number of things. Offset, alignment, ride height. I run a 255/35 on 18x9.5 +38 but with about an inch drop with -3.3 camber up front and -2 rear I do not get any rub even on track. |
You didn't state if it was the front or the rear, I am guessing the front since that's where the clearance issue usually happens. Dial back some negative camber and you may need to raise the car. In essence it's more like the tire brand than the actual size. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
