Nicks Comprehensive 86 Build - Weight Savings
Driver Name: Nick Dugdale
Member as of: 12/30/21 Car Info: 2015 Subaru BRZ Limited - 6MT Intent: Class appropriately in 'NASA TT5/ST5' Thread Goals: Building a credible weight loss database demonstrating the weight shedding potential of the 86 chassis. (Please reference this 'Google Sheets Link' to access my live weight sheet.) Honorable mentions: (FT86Club Members) • 'Official Component Weight Reduction Thread' The detailed contributions are valued greatly. • 'Anthony's FRS 4 Step Diet Program' Just an epic thread for its time. All weights are tested on one of two reliable scales in the shop. These weights are honest and can be used to figure your own losses/gains. (ACCESS MY GOOGLE SHEETS LINK) IG: nikko.zc6 Youtube: My Channel |
Great write up. One question: Is there any downside to leaving off the fuel injector covers? I left mine off when I reinstalled my engine and made an aluminum bracket for the injector ecu. Seems to work fine. I'm guessing they are there in case of a catastrophic collision.
I personally do not foresee any negative side effects to removing those heavy PI covers. I've been tracking with them off for over 6 months now with no issues. IMHO it's just more weight off the nose.
I will be going down this path very soon!
My race car is 1030KG with minimal fuel
A bit more extreme I removed the loom from the car and thinned out all the redundant wiring that was over 5kG, about the same again in unused brackets. things like the air bag impact sensors weigh a bit , only running 1 horn, lots of small things help |
FUTURE WEIGHT REDUCTION
Speculative Weight Losses - Fiberglass hollow doors -83 (Via HGK @ 8lb each) - Carbon trunk lid ~ -17 (Via Marsh OEM = 21 Lb) - Gut Headlights -5.2 (Via FT86) - Cut up dash bar ~ -5 - Remove Fog lights -2.2 (Via FT86) - Remove Dash board - 13 (Via FT86) - Remove excess wiring looms ~ -4 - Lexan Windows Via P4P (F:-14lb / R: -7lb / Sides: -2lb) Total: -23.0 - Gen 2 BRZ aluminum knuckles -8 - Lightweight flywheel - 9 - Aluminum driveshaft -12 (Via FT86) - Remove 9Lives wing - 19 - Remove center console -4 - APR carbon mini mirrors -2.5 (Via FT86) WEIGHTS I CAN'T FIND ONLINE - Wipers + Motor ? - OEM trunk and lid arms ? - OEM Steering column / Electric PS (From wheel hub to rack splines) ? - OEM Roof ? - OEM Dash Bar ? - OEM Radiator ? |
This certainly makes me wonder how heavy my car will be when its done. I'm aiming for 950kg or 2095lbs.
i could Probably take the wipers/motor out and tell you that.
3 Attachment(s)
The Lexan windows from Plastics 4 Performance should be hitting mainland US from the UK mid February. Since I have a full race cage planned for the car 'October 2022' the mission is to take out as much weight as I possibly can in preparation for the additional weight the cage will be adding later on. 2,650lb is my MCW for class. Let the fun begin! (Few photos attached from my IG) IG: @Nikko.zc6 |
Do you plan to be at VIR in March? Which region do you plan to run in? Cheers, Lutfy |
Thank you Lutfy,
Your personal build sounds great! I recently moved up to East TN from FL and will be running predominately within the NASA SE and GL regions. I will be driving with NASA SE at 'AMP' March 12-13th this year. The car is prepared for NASA's TT5 class and eventually prepared for 'Super Touring 5'. Feel free to follow the youtube channel: Nikkos Garage See you out there! |
Just an off the wall idea: Would removing the power steering assist mtr for weight reduction cause any problems. These cars seem pretty easy to steer with the engine off.
2 Attachment(s)
86 / BRZ Steering column from 'HGK' (Carbon = 4.1 lb / Steel = 7.7 lb): Carbon / Steel 86 steering column |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
