FRS Bumper swap on Facelift 2017+ GT86 Toyota
Hello everyone, would I be able to put a FRS bumper onto my 2017+ GT86? I really like the frs trd front lip. Thanks everyone!
The bumper will fit if you also swap the headlight brackets. But you need to figure out how to deal with the turn signals in the FR-S bumper. That is why no one does the swap.
The turn signals on the 2017+ GT86/BRZ shines from the headlights. Would a FRS front bumper swap affect that turn signals? |
The new bumper will not affect the turn signals in your 2017+ headlights. The FR-S has the turn signals in the front bumper. Either you can install the FR-S turn signals and wire them up in addition to the 2017+ headlight turn signals (so you will have 2 sets of turn signals on each side) or you can get something to fit into the FR-S turn signal openings. I have seen brake vents that fit into the turn signal openings before. |
Did you use the brake vents or something else? I would love to see some pics of your setup if you have any. |
You need the bumper, headlight brackets, headlights washers and caps (if you have them), tow hook cap, side blinkers brackets rivets, front logo, fog light grills (closed grills, if have fog lights, you need fog lights too).
Sitting perfectly. On the japanese market you can find a genuine Subaru accessory, led fog lights for pre facelift, made by PIAA. |
The plug is the same, but it misses the blinker wire. The FRS fog lights have 4 bolts, the facelift have 3 bolts.
You should probably get the cable for blikers and foglight from pre facelift GT86 and add a custom wire from the plug to the headlights (I don't know if this is present in facelift cars). |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
