NO SPARE for 2024??
Hey all,
I noticed after I purchased my '24 86 there was no spare in the trunk. Is that by design or is there some aftermarket kit I am not aware of? Thanks in advance. |
Looks like it isn't included:
https://www.youtube.com/watch?v=7AUbgOWmJqc |
I swapped over the spare from my '17 PP along with the styrofoam bits, all fits :)
Is the tire well also fitting the 18. Not sure how to organize it for the 18. Also, the spare needs to be something that clears the Brembo. Sent from my iPhone using Tapatalk |
https://www.*********/threads/how-to....3808/#replies |
Last generation twins came with spare in rear which had 16" wheel but there was also a different spare for performance package. Performance package spare had 17" wheel in order to fit over Brembos.
Not specific to PP or regular Spare Tire Bolt : 901720002 Spare Tire Washer: 97047FG000 Performance specific parts PP Spare Wheel: 28151FE030 PP Spare Tire: 28121VA050 PP Spare Foam Insert: 95086CA070 PP Spare Foam Spacer: 97046CA000 Regular spare Spare Wheel: 28151FJ031 Spare Tire: <Still looking> Spare Foam Insert: 95086CA040 Spare Foam Spacer: 52153PA181 |
Thanks for posting here. Was checking the tread in the other GR86 forum. All great info. Getting a trueno so I assume I will need all parts. Was previous gen PP cars 18 and spare 17? If thats the case I can do the same set up. But read that having the 17 spare on the rear there will be 0.2 difference. Will that affect? I wish that the 18 wheel and tires fit the styrofoam directly so no change will be needed . Sent from my iPhone using Tapatalk |
You never install spare in rear. If rear has puncture then you have to put spare in front and install front in rear. |
Thanks for all the great info. Looks like getting the below parts and a fitting jack (I think someone had the part # in the forum) will solve all the issue. Spare Tire Bolt : 901720002 Spare Tire Washer PP Spare Wheel: 28151FE030 PP Spare Tire: 28121VA050 PP Spare Foam Insert: 95086CA070 PP Spare Foam Spacer: 97046CA000 Sent from my iPhone using Tapatalk |
Just curious!
Does the GR86 come with the 3 pieces Styrofoams on each side and behind the seat which fits the jack and other pieces Thanks Sent from my iPhone using Tapatalk |
Perhaps a little off-topic... I think a plug-kit + pump + jack/wrench is the best combo for these cars. Just remove the tire, plug it, inflate, then re-mount. Easy peasy. (And there appears to be a cosmic rule that one will not have a flat if properly prepared for it.)
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
