Locked up engine
Anybody ever have an engine lock up but not blow up? On the front stretch at Summit Point, with no warning, I had a big noise and then no power. No smoke. No oil or coolant leaks. I coasted off the track. In the paddock, the engine could not be turned even with a big a$$ breaker bar.
I'm guessing part of the noise was 4th gear shearing off teeth. I'm going back up on Friday to pick her up and start the post-mortem. |
Uggg. Sucks. is it stuck in gear?
Sent from my SM-S901U using Tapatalk |
Damn, can’t really think of much that would cause that kind of failure and not show its insides on the outsides. Maybe something timing chain related? Hopefully it’s a transmission.
Bummer!
oh no. Sorry :( Hope it's nothing too major
Thanks guys. If it's a weird problem, it will happen to me.
The engine has Manley rods so possibly something could seize and not expel the guts. My wife is urging me to sell the car "as is" and get a Gen 2. |
I was looking forward to following your story. |
2 Attachment(s)
Number 2 piston came apart.
Among the chunks of shredded metal, we found bits of piston rings and a couple of "c" clips that I assume were wrist pin retainers. The big end of the rods and crank shaft look undamaged. I was hoping to salvage some of the parts for resale but I think the long block is headed to the scrap yard. On the bright side, the transmission and clutch are ok and I should have my FA24 in a couple of weeks. |
I am looking forward to your FA24 build
Is it worthwhile to salvage any of the engine parts for resale at a bargain price? A little extra lunch money would be nice.
It is/was a comp engine. The heads were built by Element Tuning with Ferrea big valve components. The spring kit sells for over $900 and valves range from $60-$70 each. I realize the valves in #2 are probably/maybe/most likely toast but the springs and the rest of the valves (and bank 1 head) should be fine. I don't know if anything in the bottom end is worth anything. When pulling the heads off, should I try and keep the rockers and shims matched? |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
