Need some help with some wiring
http://i57.tinypic.com/10yqlix.jpghttp://i57.tinypic.com/14axu82.jpg
Im trying to hook up my led drl fog lights. But i have no idea how to connect these 2 red wires? Do i just shove the metal piece inside and put the clear plastic piece over it? It doesnt seem to fit when i try it. Thanks in advance |
Yep, its called a bullet connector. Push hard.
:party0030: |
Thank you so much! Now while i have your attention guys which one of these wire do i tap in to so that my fogs will be on when i turn on the parking lights? Theres red black and green. I was assuming red but maybe its green...
http://i59.tinypic.com/2vx1sls.jpg |
Test with a multimeter and see which one receives about 12VDC with the key on and the light switch in the desired position. . Tap into that one.
2. Put your tongue on it KIDDING DONT! Shitty 12v tester light from any auto parts store http://smallautoparts.net/images/1315.jpg |
Im about to say screw it and tap into the red one...i doubt the power wire would be green...is that ever the case tho?
Green is most often a ground
Whats the worse that can happen if i tap into the wrong wire?
Bad - Blown control module, very expensive Moderate - Blow a 50 cent fuse, finding which is the fun part Best - It works no issues http://pennlago.com/wp-content/uploa...te-wheel-o.gif |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
