Old 04-22-2024, 05:48 AM   #1
Enigmeerkat
Enigmeerkat
Enigmeerkat's Avatar
Drives: 2015 Toyota 86 GTS
Rear Vision Mirror Rattle
Hi All,
I've been having an issue where at certain RPM (low, 2.5-3k something like that), the vibrations from my exhaust (R400) cause a resonance in the rear vision mirror, and make it rattle. Confirmed by holding it still and the noise goes away.
Any ideas how to reduce/eliminate this? I initially thought it was the prismatic flip switch but it seems to be the actual ball joint. First thought was trying to wedge some blu-tack in there, but I'm not sure that's the best idea...
2015 Toyota 86 GTS
- Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch
- PSR UEL Header, Invidia R400 Catback
- Whiteline Swaybars, 18" ROH Blue Evo R
Enigmeerkat is offline   Reply With Quote
Old 04-22-2024, 12:55 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Get a another mirror from the dealership / junkyard / webstore
EndlessAzure is online now   Reply With Quote
Old 05-10-2024, 08:55 AM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Originally Posted by Enigmeerkat View Post
Hi All,
I had the same thing when the radio in my car was played loud enough.
I took off the mirror and split it open. Then I got some foam and put it between any screwed in (circuit board for the auto dimming feature in my case) or pressed in parts before reassembling the mirror. That fixed it for me.
If you're going to try this you really have to pry the mirror open with a lot of force but it's totally doable. I used a small but strong spatula, like the ones used in smart phone repair to open the phone up.
Joon525 is offline   Reply With Quote
Rear View Mirror Rattle Gopherboy6956 Electronics | Audio | NAV | Infotainment 5 07-14-2014 10:06 PM
OEM Rear View Mirror and OEM Side Mirror hanabie Cosmetic Modification (Interior/Exterior/Lighting) 2 03-28-2014 10:07 PM
Instructional video - Window/mirror rattle DIY supramkivtt2jz DIY (Do-It-Yourself) Guides 7 03-28-2014 10:05 AM
BRZ Driver side mirror rattle with stock speakers slawdio Issues | Warranty | Recalls / TSB 2 07-01-2013 12:23 PM
Auto Dim Mirror Rattle Marcoscrdo Issues | Warranty | Recalls / TSB 1 06-13-2013 01:57 PM
