Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-04-2024, 07:42 AM | #43 |
Drives: frs
$1.5k worth of parts + $10k in labor from dealership
02-05-2024, 07:50 PM | #44 |
Drives: '13 BRZ TLM Spec
Engine was installed on Sunday, runs great! Currently have a cheapy oil filter and oil in it along with a magnetic drain plug, will drive it about 50 miles and then drain it, install a Subaru OEM filter and new oil. This will be to flush any debris that I may have missed during the rebuild.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following 7 Users Say Thank You to Opie For This Useful Post: | cueball89 (02-08-2024), FrickingReallySlow (02-06-2024), NoHaveMSG (02-05-2024), T-Steve (02-05-2024), Ultramaroon (02-06-2024), Wally86 (05-13-2024), x808drifter (02-05-2024) |
02-08-2024, 04:03 PM | #45 |
Engine #2 has been disassembled down to the bare long-block. Early indication is that this is just another lost bearing....likely #2 or #3 rod....
04-16-2024, 09:56 AM | #46 |
Got around to tearing Engine #2 down completely on Sunday, water in the oil does not make for good lubrication....and causes some different damage. As suspected/usual rod bearing #3 was literally just washed out, also the water washed the teflon coating off all of the pistons and rusted the rings. Good news, no scoring on the cams or carriers. Pickup was clean
Parts have been ordered to repair; Crankshaft Pistons (4) Ring set ACL Main Bearings ACL Rod Bearings Connecting rods (2) Misc gaskets, seals, orings, etc... Going to hone the bores, disassemble, clean and oil everything then reassemble once the parts arrive.
The Following 3 Users Say Thank You to Opie For This Useful Post: |
04-16-2024, 01:18 PM | #47 |
chicken tonight
Interesting to see the results of different failure modes. Thanks for sharing!
The Following User Says Thank You to Ultramaroon For This Useful Post: | Opie (04-16-2024) |
04-16-2024, 02:03 PM | #48 |
Drives: X5 35d, D90, CX-5 Turbo
Water in the oil, rusted piston rings, flood car?
~Scott T.
'95 NAS D-90 ST '13 BMW X5 35d '22 CX-5 Turbo '?? 86 one day soon? |
04-17-2024, 07:34 PM | #49 |
Water sucked into the engine driving through standing water....not flood.
04-18-2024, 08:33 AM | #50 |
Drives: 2013 frs base
04-18-2024, 11:26 AM | #51 |
It did not, spun freely when I got it. Quite honestly it looks like someone added water to the oil....insurance scam?
04-23-2024, 07:47 PM | #52 |
Jeesus, I think the tech that did the valve spring recall on this motor used several tubes of RTV....and forgot to install the right side oil spacer that keeps the oil slung off the cams from aerating....maybe why there was so much oil foam in this engine....
New crank & rod bearings, new pistons, rings, 2 connecting rods installed....just waiting on the oil spacer to come in in order to complete the right cam carrier....
The Following 2 Users Say Thank You to Opie For This Useful Post: |
05-02-2024, 04:20 PM | #53 |
Shop vac after cleaning all the old RTV from this engine before it gets reassembled.
Think it's a bit much? Good job Ken Ganley Subaru North Olmsted... BTW, that's a 12 gallon Shop Vac for reference...
05-07-2024, 02:03 PM | #54 |
All back together and good as new.
New components installed/replaced during rebuild: Subaru OEM Crankshaft ACL Race Series Main Bearings 5M8312HX-STD ACL Race Series Rod Bearings 4B8310HX-STD Subaru OEM Connecting Rods (2) Subaru OEM Pistons (4) Subaru OEM Ring Set Subaru OEM Engine Gasket Set Subaru OEM Cam Carrier Filters (4) Subaru OEM Oil Filter Subaru OEM Spark Plugs (4)
The Following 5 Users Say Thank You to Opie For This Useful Post: | blsfrs (05-09-2024), Code Monkey (05-07-2024), Ultramaroon (05-08-2024), Wally86 (05-13-2024), ZC6_STi (05-07-2024) |
Tags |
ken ganley subaru |
Similar Threads | ||||
My OFT v2 Story. | Th3rdSun | User/Vendor/Sponsor Reviews, Feedback, Comments | 53 | 04-19-2023 10:06 PM |
Toyota GT86 FA20D cylinder head tuning for the naturally aspirated engine my details | Little Samurai | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 03-30-2022 03:37 PM |
R32Gaijin’s BRZ story | R32Gaijin | Member's Car Journals | 0 | 09-15-2019 11:03 AM |
A story for the day | humfrz | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 05-31-2016 09:57 AM |
Story | pushrod | Off-Topic Lounge [WARNING: NO POLITICS] | 780 | 05-12-2015 09:41 AM |
