Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
01-12-2023, 02:18 PM | #1 |
Drives: 2014 Scion FR-S
Which Motul oil to use?
Hi all, question about engine oil. What is the difference between the different Motul 8100 oil types. Which one should I be using? Previously I used Motul 8100 Eco-lite 0w20. I live in Miami and want to try 5w30 with the hotter climate down here. Good idea?
I'm stock besides catless uel header and E85 OFT tune. Most all my commuting is very short trips. I will also be adding LiquiMoly MoS2 Anti friction Treatment. The types Amazon has are below. Any recommendation would be appreciated. Thanks! Eco-energy. Exo-lite. X-clean efe c2/c3. X-clean + c3 |
01-12-2023, 06:03 PM | #2 |
The weight is more important than anything else. The formulations are for different standards.
If you want the best protection, just use 300V. It's straight up more durable with more additive. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Tatsu333 (01-27-2023), x808drifter (01-13-2023) |
01-24-2023, 03:23 PM | #3 |
So the 300V in 0w20 then? Needing to do a fluid change on mine and I was running thicker oil at your suggestion before I had an oil cooler installed, but thinking I can go back to 0w20 now that I've got it. Right? (car is road driven sparingly (weekend trips) and 3-5 track days a year, open to any options)
01-24-2023, 04:18 PM | #4 | |
It'll largely depend on your driving habits and ambient conditions. Second gen cars should be 30 weight universally, IMO. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Tatsu333 (01-27-2023), x808drifter (01-26-2023) |
01-24-2023, 05:06 PM | #5 | |
First gen car ('17) with low miles (20K) so I should run 0w20? or 5w30? Probably sees 2k of street driving a year (spring/summer/fall) but nothing that would have me worried about temps. |
01-24-2023, 10:18 PM | #6 |
If your temps are in line, then use the factory recommendation of 0W20.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
01-25-2023, 08:21 AM | #7 |
01-25-2023, 01:31 PM | #8 |
<--- this guy uses the High RPM 300V 0w-20 and the oil analysis results have been good so far.
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post: |
Similar Threads | ||||
Motul 300 LS | 54fighting | Engine, Exhaust, Transmission | 2 | 11-19-2020 05:22 AM |
Motul coolant | leevanf | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 03-25-2018 02:38 PM |
Motul 8100 Eco Lite vs Motul 300V vs Eneos Sustina | Lust | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 58 | 08-28-2017 07:10 PM |
motul 300 vs motul 300ls about to buy some need help. | NickFRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 03-24-2016 10:51 PM |
motul Oil | whitefrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 05-24-2013 10:12 AM |
