Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-21-2022, 01:11 AM | #1 |
Drives: Black 2015 BRZ
Auto-Tranny shifting issue
Hello all, I've searched and searched the internet for a fix for my Automatic trans shift problem/slippage and Honestly im stumpt. I have no leads, no ecu codes and im just at a complete loss. The car only has 25k original miles, not boosted, and I have no clue why this issue is happening. Anyone have any clues?
EDIT: at one point i had a p0700 code but that is it. Video is below. What I have tried: I replaced the torque converter completely, with a brand new OEM one and it did not fix it. That came with a transmission oil change, and diff oil change. We inspected all connectors and plugs and nothing looked out of order. VIDEO: Last edited by SushiBRZ; 01-21-2022 at 01:29 AM. |
01-21-2022, 07:23 PM | #2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You looked at the wrong control module captain.
P0700 is a general transmission fault that sets in the PCM at the request of the TCM, which is where the trouble code that could have helped you was. You get to the TCM with a better scan tool. |
01-21-2022, 07:30 PM | #3 |
I got the code when I was tuning with the OFT I think thats what caused it, because since reverting back to stock tune, the check engine light disappeared.
01-21-2022, 10:13 PM | #4 |
Drives: 17 BRZ
dang what tune did you use before going back stock?
have you tried re-flashing stock tune? |
01-21-2022, 10:17 PM | #5 |
01-21-2022, 10:21 PM | #6 |
Drives: 17 BRZ
hmmm same issue in auto mode? was the video in manual shifting mode?
I'm also AT on stage 2 but its customized. |
01-21-2022, 10:29 PM | #7 |
01-30-2022, 05:47 AM | #8 |
Drives: FT86
https://www.ft86club.com/forums/show...55&postcount=2
TSB out on idle and hard shift issue on 2015 auto, Auto trans computer updated software |
01-30-2022, 05:06 PM | #9 | |
02-01-2022, 11:45 AM | #10 |
Drives: Scion FRS 10 series
It doesn't hurt to update the transmission software, issue seems to be the transmission valve body solenoid not engaging on command. you can probably find a whole used auto transmission to swap out or go to a transmission shop to diagnose the issue which would cost the same in parts and labor. good luck on the issue
02-01-2022, 11:49 AM | #11 | |
02-01-2022, 12:21 PM | #12 |
Finding a complete low mileage transmission to swap in would be your best option, I've seen some on ebay off 541 motorsports for around $700 shipped
02-01-2022, 12:31 PM | #13 |
03-25-2024, 03:55 AM | #14 |
vroooooooom
Drives: 86
Were you able to fix this issue?
Tags |
automatic, help please, transmission |
Similar Threads | ||||
AT Tranny Issue | Riftur | Engine, Exhaust, Transmission | 35 | 02-01-2018 11:23 AM |
Clutch/tranny issue diagnostic help | yomny | Engine, Exhaust, Transmission | 46 | 08-26-2015 12:48 PM |
Shifting issue? | RaveSaint5 | BRZ First-Gen (2012+) -- General Topics | 30 | 10-20-2014 01:21 PM |
High RPM Shifting Issue? | Rinzler | Issues | Warranty | Recalls / TSB | 5 | 05-17-2013 12:30 AM |
Is the auto tranny from a isf? | WolfsFang | Engine, Exhaust, Transmission | 6 | 08-25-2012 09:25 PM |
