Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
03-17-2018, 06:10 PM | #1 |
Which style phone mount is best ?
Vent mount or windshield suction mount?
Magnetic or spring clips? Threads are old. Options change. Anyone got something they like? |
The Following User Says Thank You to GrantedTaken For This Useful Post: | JoeC (03-17-2018) |
03-17-2018, 06:24 PM | #2 | |
Drives: 16 FR-S Raven
Sent from my Pixel XL using Tapatalk |
03-17-2018, 06:30 PM | #3 |
I've decided I want to avoid the spring clamp kind.
I want a magnet one. |
03-17-2018, 06:41 PM | #4 |
I have this one mounted to the right of my head unit. I love it. Can see it easily & can plug it in with a 6” charging cable.
03-17-2018, 06:41 PM | #5 |
Drives: 2014 BRZ Limited
This is the best one I've found:
The Following User Says Thank You to extrashaky For This Useful Post: | Audio (03-17-2018) |
03-17-2018, 07:33 PM | #6 |
How about "mounting" it inside the glove box ??
humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | bkharmony (03-19-2018), Impureclient (03-17-2018) |
03-18-2018, 07:47 AM | #7 |
22R
Drives: 2012 Camry SE 2017 Toyota 86
3D printed from forum member and installs without tools and is removable. Just add your mag mount of choice.
The Following 3 Users Say Thank You to 22R For This Useful Post: |
03-18-2018, 09:05 AM | #8 |
The Dictater
Drives: '13 Red Scion FRS
Not new or anything, but I have a generic suction mount on the little side window next to the mirror. I'm away from my car, so I can't take any pictures right now.
Pros: -Easy to glance at if using for navigation -Not in the way of anything important Cons: -Needs a long charger cable and clever routing due to opening the door. -Out of reach of passenger if you need them to do something (my fiance is usually the navigator) |
03-18-2018, 10:23 AM | #9 | |
There's a little square gap at the top of that panel just big enough to let a cable pass through. It's as if it were designed to allow this. I have the cable run to a USB power port mounted to the steering support member under the dash (not shown). I have the USB port powered off the heated seat circuit in the fuse panel under the dash right there using an add-a-circuit. It makes it a lot cleaner than having to plug it in somewhere. Eventually I'm going to run that cable through the boot in the door hinge and out the little gap next to the small window, so that it doesn't need any slack to open and close the door. |
03-18-2018, 01:44 PM | #10 | |
The Dictater
03-19-2018, 10:01 AM | #11 |
Drives: 2013 FR-S MT Hot Lava
That's the exact one I have. It's good,but the claps are slow moving in the winter when it's cold.
03-19-2018, 10:13 AM | #12 |
03-19-2018, 10:13 AM | #13 |
The Gunshine State
Drives: '14 BRZ Limited
I've been using this mount for a few months and love it, only thing is you will need a case for the phone that covers the back so you can place the magnet inside (unless you don't mind a magnet sticker on your phone).
http://www.hdaccessory.com/products/...IaAj4-EALw_wcB
Current DD: M235i |
Similar Threads | ||||
Custom phone mount | so26 | DIY (Do-It-Yourself) Guides | 20 | 11-07-2016 04:15 PM |
Stealth Phone Mount (Magnet) | KevinB85 | BRZ First-Gen (2012+) -- General Topics | 23 | 07-20-2015 11:47 PM |
Best phone mount? | JS + BRZ | Electronics | Audio | NAV | Infotainment | 9 | 03-24-2015 09:02 AM |
ProClip custom phone mount | seanyboy | Interior Parts (Incl. Lighting) | 1 | 03-27-2014 11:46 AM |
DIY phone mount | GaDgeT | Electronics | Audio | NAV | Infotainment | 2 | 07-05-2013 10:18 PM |
