Old 11-03-2023, 04:31 PM   #1
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Which wheels clear the Brembo B-M4 BBK
Similar to my earlier thread which was a huge success, I'm starting a new thread to figure out which wheels clear the Brembo B-M4 BBK which is a somewhat common recommendation. Here's my review of that kit.
Please contribute with photos and wheel specs of cars you know run this kit!
Also attached is a template you can use to check your own wheels.
In alphabetical order:
Apex Wheels
ARC-8 17x9.0 +42 FIT
SM-10RS 17x8.0 +40 require a 5+ mm spacer (claimed by Apex, evidence needed)
VS-5RS 17x8.0 +40 FIT (claimed by Apex, evidence needed)
VS-5RS 17x8.5 +44 FIT (claimed by Apex, evidence needed)
VS-5RS 17x9.0 +48 FIT (spacer was used for non-BBK reasons)
Enkei
RPF1 17x8.0 +35 DO NOT FIT
RPF1 17x9.0 +35 DON'T EVEN ASK
Titan 7
T-S5 17x9.0 +37 FIT
T-S5 17x9.0 +47 require a spacer (10 mm seems to work)
File Type: pdf Wheel clearance template for Brembo B-M4.pdf (59.9 KB, 70 views)
Follow the build thread for my GR86!
Old 11-03-2023, 04:38 PM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
It looks like Enkei RPF1 17x8.0 +35 won't fit without a massive spacer.
Old 11-26-2023, 02:37 AM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I can add the following fitment details.
I'll note that the space from the caliper to the barrel on many 17 inch wheels is very tight, such that I don't recommend placing balancing weights here because they're liable to get torn off if even a small pebble gets caught.
Konig Hypergram 17x9 +40 - fits, no spacer needed.
Phatfux Ballzy 17x8 +35 - spoke interference, 3mm spacer required.
Unknown 6 spoke 17x6 +48 - spoke interference, 5mm spacer required.
OEM space saver spare - complete wheel interference, 55mm spacer required.
Lynxis is offline   Reply With Quote
Old 01-14-2024, 10:59 PM   #4
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Both the 6UL 17x9 +48 and the Apex 17x9 SM10RS +48 fit with the Brembo BM-4 calipers. The 6UL fits without a spacer. I never tried the Apex w/o a spacer.
Wangspeed is offline   Reply With Quote
Old 05-05-2024, 03:08 AM   #5
ruturaj001
Drives: BRZ 2023
Can anyone send me copy of the template?
ruturaj001 is offline   Reply With Quote
Old 05-05-2024, 07:14 PM   #6
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
It’s attached as a PDF to the first post
The Following 2 Users Say Thank You to Wangspeed For This Useful Post:
Lynxis (05-05-2024), ruturaj001 (05-05-2024)
Old 05-05-2024, 10:12 PM   #7
ruturaj001
Drives: BRZ 2023
Thank you. I am blind 🤣, I looked at all links but not the actual attachment. I sent it to konig to check if 17x8 ultragrams fit.
Old 05-07-2024, 02:13 AM   #8
ruturaj001
Drives: BRZ 2023
Heard back from konig, ultragrams 17x8 and Heliograms 17x8.5 both fit
Do stock non-pp BRZ wheels clear 17+ BRZ PP rear Brembo graywzc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-21-2020 10:47 PM
SSR GT2 17x7.5 +48 clear BRZ brembo brakes? artongdou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-23-2018 06:28 PM
Help : Enkei RPF1 Clear STi Brembo's?? yoonjin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-19-2014 11:45 AM
Brembo GT Kit Fitment on Enkei Wheels Parikh1234 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-17-2014 09:12 AM
Does anyone know if TSW Nurburgrings clear STI brembo's? SkAsphalt Wheels and Tires 0 05-14-2014 04:04 PM
