Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
02-06-2023, 01:23 PM | #1 |
Vented sway bar bushing shield
I’m currently swapping over 2022 GR86 front crossmember/ skid plate parts to my 2013 and discovered that there is a new passenger sway bar bushing shield that has vents in it. I imagine this is because the exhaust is so close to the bushing. Direct fit for all my models looks like, but have not yet confirmed. Will do once I get home from work today.
The Following 3 Users Say Thank You to norcalpb For This Useful Post: |
02-06-2023, 03:56 PM | #2 |
SU003-09172? Is it plastic made?
02-06-2023, 04:42 PM | #3 |
The Following User Says Thank You to norcalpb For This Useful Post: | gpvecchi (02-07-2023) |
02-07-2023, 10:34 PM | #4 |
Before and After.
After taking a look at it installed, the vents seem to be facing the direction of airflow so they are probably intake holes for the secondary cat. For some reason I also thought this piece completely covered the bushing but it sits just below them. Last edited by norcalpb; 02-07-2023 at 10:45 PM. |
The Following 9 Users Say Thank You to norcalpb For This Useful Post: | Capt Spaulding (02-08-2023), DarkPira7e (02-08-2023), femaledog (02-08-2023), gpvecchi (02-08-2023), Jdmjunkie (02-08-2023), makinen (02-08-2023), NoHaveMSG (02-08-2023), RedReplicant (02-08-2023), x808drifter (02-09-2023) |
02-08-2023, 04:15 PM | #5 | |
Drives: Toyota GT86
tomorrow i use my dremel, speed holes! |
The Following 3 Users Say Thank You to Ruben_86_ For This Useful Post: |
03-04-2024, 04:21 PM | #6 |
Drives: 2020 BRZ Limited
Interesting, I have a related thread here:https://www.ft86club.com/forums/showthread.php?t=154522
Does this venting actually help with overpipe temps and sway bar bushing melting issues? I feel like the venting seems like it wouldn't do a lot for the bushing which sits at the side of the overpipe which is closer to the engine and well ahead of the vents |
Similar Threads | ||||
Failing Sway Bar Bushing? | jkost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 04-20-2021 04:14 PM |
Rear sway bar bushing | T0rt0r0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 11-10-2018 02:41 AM |
Is this a busted sway arm bushing? | ironsurfer129 | Issues | Warranty | Recalls / TSB | 9 | 08-26-2017 01:09 AM |
Whiteline Front and Rear Sway Bar + Bushing Kit $550 | MicheleAbbate | Brakes, Suspension, Chassis | 1 | 01-28-2015 11:23 AM |
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 12:38 PM |
