Old 12-10-2021, 07:14 AM   #15
IamKevin2
Drives: 2017 Toyota 86
Originally Posted by ZDan View Post
You are on the right track, research first, then commit...
I don’t have too much time to do research tho
IamKevin2 is offline   Reply With Quote
Old 12-10-2021, 07:14 AM   #16
IamKevin2
But, I’ll try my best, thanks
Old 12-10-2021, 11:46 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Aftermarket wheels are an option, not a requirement. You have all the time you need. I'd recommend looking into different sizes and offsets. If you go too wide or don't run the right offset you may run into strut clearance issues.
Old 12-10-2021, 04:15 PM   #18
IamKevin2
You might want to reconsider that size/offset! Unless you have cutout arches and flares, you're going to poke and rub like crazy... Do they come in +35 offset? That should work with 245/35-18s, if you have some negative camber... Is car lowered and if so how much?
Oh yea, the car is completely Stock, aside from the cut out diffuser but I don’t think that really matters. I mean, what if I get the +22 rays, and save up money to get the chamber I need then lower the car
Old 12-10-2021, 04:31 PM   #19
IamKevin2
Yes Ik, but the tires aren’t. I kind of need them immediately. My rear tires are bald and my dad keeps pushing me on getting new tires. So I thought get them all together while I have the chance
Old 12-10-2021, 04:48 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
I would not get the +22s...
Even at +35 you'll need some negative camber to keep the fronts from sticking out. +22 is just going to be a disaster without significant camber and some bodywork.
Even with +35, IMO you'll want to lower it a bit and get significantly more front camber than stock to tuck the front tires in.
Old 12-11-2021, 09:24 AM   #21
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
After reading all this.
Just get new tires for your OEM wheels.
You are WAY in over your head right now.
The Following 4 Users Say Thank You to x808drifter For This Useful Post:
Calum (12-11-2021), Jdmjunkie (12-11-2021), nathand (12-11-2021), NoHaveMSG (12-11-2021)
Old 12-12-2021, 07:30 PM   #22
IamKevin2
Yea I am , but like, when I do have the knowledge and know what I’m doing, I don’t want to waste even more money on new tires to fit the new wheels
Old 12-14-2021, 04:39 PM   #23
meWant
Drives: '16 BRZ Limited
Think your best option might just be get new tires for stock now and then whenever it's time to replace the newly purchased tires then you can buy a wheel & tire package to allow yourself time to research and not rush into a purchase.
meWant is offline   Reply With Quote
The Following 3 Users Say Thank You to meWant For This Useful Post:
Jdmjunkie (12-14-2021), nathand (12-15-2021), NoHaveMSG (12-14-2021)
Old 12-15-2021, 02:55 PM   #24
nathand
Drives: 2016 HyperBlue
Just imagine how much money you will waste if you buy something that does not fit.
Here is some good fit advice.
https://support.apexraceparts.com/hc...-Fitment-Guide
nathand is offline   Reply With Quote
Old 12-16-2021, 12:15 AM   #25
IamKevin2
This is perfect, thank you very much
The Following User Says Thank You to IamKevin2 For This Useful Post:
nathand (12-16-2021)
Old 02-01-2022, 03:57 PM   #26
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
I went for 17x9 +38 for my 57CR's. Like others have said, fitment is flush with the fender when running some camber (no more than 2 deg). 245/40/17 PS4S tires.
I honestly can't complain. It super grippy and looks/feels fantastic. I went with 17's instead of 18's because I did not want to mess with my speedometer. Mine is so far only a daily/weekend car until it looses its virginity to the track.
GPhilly is offline   Reply With Quote
Old 02-05-2022, 12:57 PM   #27
IamKevin2
I see, after some time tho, I probably just gonna go with some KNPs instead of the rays, but if I do go with rays , I’ll come back to this, so I appreciate it
Old 02-07-2022, 09:51 AM   #28
GPhilly
GPhilly's Avatar
Those look super fresh too, I would definitely get those. If you go with a similar setup to mine you won't be disappointed!
WTB: RAYS 57CR Gold Clark20 Want-To-Buy Requests 0 02-14-2020 07:25 PM
FS:[IL/WI] RAYS Engineering 57CR 18x9.5 EDP | NEW IN BOX BanditKeith Wheels and Tires 2 01-24-2020 07:24 PM
Rays Gram Light 57CR - ALL NEW COLORS FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 04-05-2018 05:41 PM
RAYS Gram Light 57CR DesertLava Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-26-2017 11:55 AM
New Rays Gram Lights 57CR - ALL NEW COLORS FT-86 SpeedFactory Wheels and Tires 3 08-07-2017 09:45 AM
