Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
12-26-2023, 03:33 PM | #1 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
Do FA20s normally get this dirty after ~80k miles?
I removed the manifold on my engine and found quite a bit of gunk in the intake manifold and ports. Is this normal for an FA20 with about 80,000 miles on it? It’s all oily, gunk that wipes off relatively easily, but I don't have experience with how dirty these motors can get and this seems excessive. Also, this is a replacement motor and I know nothing of its history beyond that it was compression and run tested by the seller, so I'm wondering if this maybe indicates how this FA20 was run before me.
Sorry if there are already plenty of posts about this, but I always get an error now when I try to use the forum search function. |
12-26-2023, 04:15 PM | #2 |
AutoX-10/10ths every run
I think a catch can would help with this. Even NA I got a decent amount of blow-by and I suspect what you are seeing is a result of blow-by.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
12-28-2023, 09:46 PM | #3 |
Drives: Crapcan
That’s a bit heavier than I expect to see at that millage. A leak down is a better test than just compression. You could also try a WRX pvc. Bit stouter for the boost.
12-30-2023, 09:16 AM | #4 |
Ultra Senior Member
I should add that, from the salvage pictures of the donor vehicle, the previous user at least wasn't running any FI and everything appeared to be stock from what I saw in the engine bay. Of course, that says nothing about how it was driven or was running an other-than-factory tune on the ECU.
01-02-2024, 11:42 AM | #5 |
Drives: '13 BRZ TLM Spec
Looks normal to me. Many intakes on modern engines get soot like this due to the EGR systems. I'd recommend replacing the PCV when installing it and using some intake and carb cleaner to clean it up.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
01-14-2024, 07:50 AM | #7 | |
Ultra Senior Member
03-28-2024, 02:22 AM | #8 |
I thought port injection was supposed to help with exactly this issue?
03-28-2024, 06:28 AM | #9 |
Drives: 22 BRZ limited
It did help with the issue. The port injectors won't keep it spotless.
03-28-2024, 05:49 PM | #10 |
friendly
Drives: 17' 86
Recently removed my manifold for injector replacement and my valve were pretty spotless at approx ~70k miles. I have often run ethanol though.
I will likely be pulling manifold again soon and will check how they look post boost.
Seek comfort in discomfort.
The Following User Says Thank You to alphasaur For This Useful Post: | Teseo (03-28-2024) |
Similar Threads | ||||
Possible for our FA20s to have the Torque Curve of the FA20DITs? | brzfl | Forced Induction | 21 | 02-21-2017 07:43 AM |
Post your dirty 86 | Rayme | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 31 | 02-17-2013 04:19 PM |
Dirty drifting in the FRS. | dem00n | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 11-03-2012 06:31 PM |
Windshield appear to be dirty. | trueno86power | Issues | Warranty | Recalls / TSB | 17 | 08-03-2012 02:20 PM |
Clean & Dirty | trueno86power | Other Vehicles & General Automotive Discussions | 1 | 02-07-2012 12:54 PM |
