Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-25-2019, 03:05 AM | #127 |
Drives: Full HKS GT86
Now running this kit myself on a stock engine with updated rods, injectors, 2.75 inch exhaust etc.
Sent from my SM-G950F using Tapatalk |
02-24-2020, 10:01 AM | #128 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
02-24-2020, 10:09 AM | #129 |
Drives: Toyota Gt86 -2015- Grey
02-24-2020, 11:08 AM | #130 |
Wes
how many hours of labour did it take to install the stroker kit and the valve train?
Instagram: @gt86ws
02-24-2020, 11:15 AM | #131 |
Drives: brz 2017 hksv2
anyone knows how to lower minimum boost on this kit?
is there a spring available to put in the wastegate with lower pressure? |
02-24-2020, 05:13 PM | #132 | |
Drives: Q5 + BRZ + M796
[ame]https://www.youtube.com/watch?v=mkoynZv-24o[/ame]
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | tomm.brz (02-24-2020) |
02-27-2020, 12:47 AM | #133 | |
Hawaii
Drives: HKS Turbo 2017 BRZ
Might want to see if that is possible since they're in partnership with delicious. Difficult thing may be the time zone differences. |
03-28-2020, 07:00 PM | #134 |
Detective John Kimble
Drives: 2016 FR-S
Does this kit have a blow off valve? I suppose if it did, the MAF sensor would be fucked for a few seconds after the boost pressure is released
06-02-2021, 05:52 PM | #135 |
Drives: 2015 Subaru BRZ Sport Tech
For those who are worried, this kit is capable of running 10psi. 12 is not the lowest. Out the box, the initial boost pressure actuator is set at 13psi but can be brought down by adjusting the actuator rod/plate positioning in conjunction with running HKS catted downpipe or using stock front pipe. This will keep boost pressure under 10psi.
06-09-2021, 11:25 PM | #136 | |
Drives: 18 BRZ tS, 27 GRMN 86
Thanks |
05-26-2023, 11:00 AM | #137 |
Drives: 17 BRZ
I know someone who is running stock injectors and pump, on E85 Flex with this kit pushing 7PSI using a Turbosmart Actuator PN (TS-0681-5072). Just need more power nothing crazy, this fits my needs. I'm going with this setup lol
The Following User Says Thank You to Espi For This Useful Post: | Teseo (05-27-2023) |
08-04-2023, 07:29 AM | #138 |
Drives: 17 BRZ
Reached out to JDL and they made me a better manifold than what comes with this kit. Just to follow up on my last post 7PSI WG installed:
Fun times ahead! Last edited by Espi; 08-23-2023 at 07:51 PM. |
08-29-2023, 01:48 PM | #139 |
Drives: 17 BRZ
Little gem I came across yesterday. Looks like DK now also fitted the HKS kit. Notice 6:49 time stamp regarding the manifold "this item is not from HKS". As I suspected, but now confirmed by HKS!
If you want a better manifold hit up JDL The bronze coating on my existing JDL header is REALLY good at keeping temps down. So I went with the same (plus its slightly UEL), the DP is still the one the kit came with but also coated: Just waiting on Koyo to restock the radiator I need to finally get everything installed. (5 week wait time FML) I have everything else I need to make this install right. - JDL 10AN oil return line kit to replace the rubber HKS oil return line - JDL 10AN tapped oil pan - JDL Slim fan kit - Greddy Oil Pan baffle and Killer B pickup tube (Ty CSG) - Custom front crash bar - Koyo rad radiator parts and just waiting now for the actual radiator.. ughh Almost there! Cheers |
08-29-2023, 05:34 PM | #140 | |
JDM Spirit of the '90s
Drives: 2015 FR-S Turbo
Very nice selection of parts you got there. I also got the HKS kit and have been enjoying it since 2018. For those who want to know about my setup: -HKS GT3-RS with catted downpipe -JDL Super quiet catted/resonated front pipe -JDL slim fan kit -Custom crash bar -Jackson Racing dual radiator/oil cooler -R1 Titan cat-back exhaust -Ptuning flex fuel kit -1050x Injectors -Ecutek tuned by CSG -Boost ~10psi -Ogura Racing Clutch w/lightweight flywheel 400LD-TT -VLS gauges (boost/AF ratio/Oil pressure)
The Following 2 Users Say Thank You to Raven86Project For This Useful Post: | Espi (08-29-2023), villainous_frx (08-30-2023) |
Similar Threads | ||||
Never been so excited for an oil change... | No Limit Motorsport | Engine, Exhaust, Transmission | 20 | 09-27-2012 11:59 PM |
Beyond excited!! | debs0712 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 06-27-2012 09:03 PM |
Excited!!!!!! | Filipino Royale | BRZ First-Gen (2012+) -- General Topics | 2 | 06-13-2012 10:14 PM |
So excited to be here!!!! | staycrushing | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-31-2012 07:05 PM |
Brisbane get excited! | spr1nter | AUSTRALIA | 29 | 05-14-2012 07:07 PM |
