Old 01-15-2024, 07:37 PM   #127
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What kind of switch is that on your Accusump?
Old 01-16-2024, 04:01 PM   #128
gt5759
Drives: 2017 BRZ
It's an electric ball valve. They are a little bigger, but they work better IMO than a solenoid style control (seals better, isn't energized constantly in its open state) now if you want the accusump to have a controlled on/off that's fast then the solenoid is the way to go.
gt5759 is offline   Reply With Quote
Old 01-17-2024, 08:47 AM   #129
blsfrs
blsfrs's Avatar
Thanks. Brand?
Old 01-17-2024, 10:21 AM   #130
gt5759
Drives: 2017 BRZ
Thanks. Brand?
https://ussolid.com/motorized-ball-v...u-s-solid.html
The Following User Says Thank You to gt5759 For This Useful Post:
blsfrs (01-17-2024)
Old 01-18-2024, 12:24 PM   #131
blsfrs
blsfrs's Avatar
According to their specs, the flow medium max temperature is 194*. How hot will your oil get? The max ambient temp is 104* so, for me, I probably wouldn't want it on my Accusump under the hood.
Old 01-18-2024, 04:03 PM   #132
gt5759
Drives: 2017 BRZ
Yeah, I wouldn't suggest putting it in the engine bay, I have zero experience with that either, but I do know they work well when inside the car. Normally in the passenger side area or in the trunk.
Oil temps wise I normally see 235* to 250* in the pan and about 20* to 30* less after the cooler at the filter adapter. I know the accusump gets hot enough I don't want to touch it after a race but that's as much data on that standpoint that I have.
blsfrs (01-19-2024)
Old 02-06-2024, 12:01 PM   #133
gt5759
Drives: 2017 BRZ
Plumbing is coming together, still waiting on some more materials to finalize connections on hoses, insulation wrap and what not but basically, it's all there now.
All of the electronics are now in the car as well other than mounting the rear-view camera. I keep telling myself I'm racing this full season and not just fixing everyone stuff!
Hard lines will be done in the tunnel once the drivetrain comes back out here probably this weekend.
The Following 3 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (02-07-2024), RedReplicant (02-06-2024), Wangspeed (05-05-2024)
Old 04-03-2024, 06:06 PM   #134
gt5759
Drives: 2017 BRZ
More time spent on Lucille. Everything is in the car now and wiring is beginning to spread
mounting for the screens on the doors
So I'll back up a little, a few little things still need to go in such as the 80-amp breaker for the ESP and the canbus hub but other than that it's just stringing wire, looming and terminating now! Wires in the last pic are not final, its just a in progress moment. Spent a little over 5 hours Sunday just working on the software for the pdm and ecu
Firewall wire penetration is via radlok for the main power like the pdm and deutsch bulkheads. Those are installed now but I forgot to take a pic!
The Following 8 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (04-04-2024), Code Monkey (04-04-2024), DocWalt (04-04-2024), redlined600 (04-04-2024), RedReplicant (04-03-2024), Ultramaroon (04-05-2024), villainous_frx (04-04-2024), Wangspeed (05-05-2024)
Old 04-03-2024, 10:15 PM   #135
redlined600
redlined600's Avatar
Drives: Fr-s
Was the motivation behind going with cameras over mirrors drag reduction or something else? Do you have them tied into a recording system?
Old 04-04-2024, 12:04 PM   #136
gt5759
Drives: 2017 BRZ
Hit it on the head! Aero was first, then visibility bonus - between all three cameras I can see 90* out from the doors all the way around very clearly. Video recording use is there and will be used later for race videos but mainly logged for use in car contact issues on track.
blsfrs (04-04-2024), redlined600 (04-04-2024), Ultramaroon (04-05-2024)
Old 05-05-2024, 06:09 PM   #137
jflogerzi
jflogerzi's Avatar
so much win. really nice looking race car!
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Jensen NASA ST4 race build thin2win Member's Car Journals 18 04-14-2021 12:15 AM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
Car 986 Scion FR-S NASA PTD Race Car Build phastafrican Member's Car Journals 70 01-03-2015 09:32 PM
