02-06-2022, 03:14 PM | #1457 |
Drives: 2015 firestorm scion FRS
fdf mantis angle kit vs. PBM vs wise fab? thoughts, opinions?
2015firestormFRS thread
http://www.ft86club.com/forums/showt...43#post2061943 |
02-22-2022, 12:24 PM | #1458 | |
team TEMPEST
Drives: 2015 Scion FR-S
I'd say WiseFab is a close second, I can't say much for PBM but I myself am planning on running the FDF kit coming up
"I don't want to regret the way I lived"
05-27-2022, 11:59 PM | #1459 |
Drives: 2017 BRZ
If you've got PBM version 1 knuckles and want to sell, get at me ASAP
10-23-2022, 09:45 PM | #1460 |
Shitbox enjoyer
Drives: BRZ (2013)
If I'm having issues with clearance with the side walls after installing longer tie rods should I grind off the sections its hitting or install spacers / smaller wheels?
10-25-2022, 04:01 AM | #1461 |
Drives: 2013 FRS
You might want to share a picture as well as your tire size and wheel specs (diameter, width and offset)
10-25-2022, 06:55 PM | #1462 |
Shitbox enjoyer
Drives: BRZ (2013)
I'm not at home and I'm really stupid so I don't have all that info. I'm running 17'' standard wheels and -2* camber in the front. I have the Megan inner tie rods and P2m outer tie rods.
10-28-2022, 02:31 PM | #1463 |
Drives: 2013 FRS
Going off what you're saying, if you're running adjustable outer tie rods and the tie rod is hitting your inner wheel barrel, you could push the wheel out with a spacer.
Take some pics and share the specs when you have a chance. |
11-18-2022, 02:12 PM | #1464 |
Shitbox enjoyer
Drives: BRZ (2013)
After putting on spacers and maxing out the camber the only place its rubbing now is this small portion of the frame just on one side (probably due to frame damage). I assume I just take an angle grinder to this, shave it up a bit and I'm done right? |
11-20-2022, 01:55 AM | #1465 |
Drives: 2013 FRS
I'd prob take a hammer to that.
11-26-2022, 10:56 PM | #1466 |
Shitbox enjoyer
Drives: BRZ (2013)
11-30-2022, 02:05 PM | #1467 | |
Drives: 2013 BRZ HKS Turbo
How much is "a ton" of camber? You'll want somewhere around -4* ideally for drift.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
12-03-2022, 03:33 PM | #1468 |
Shitbox enjoyer
Drives: BRZ (2013)
Im at -3.5. Is there any reason not to run 16 inch tires? I feel like I could take off the camber when I felt like it and not rub if they were that small.
12-05-2022, 12:17 PM | #1469 | |
-3.5* front camber is pretty good for drifting. I'd say you should have more negative camber.
The Following User Says Thank You to terboboost For This Useful Post: | Falkon240 (12-05-2022) |
12-05-2022, 02:08 PM | #1470 | |
Drives: 2013 FRS
Similar Threads | ||||
Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
BRZ Drifting. | Hunter | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 09-20-2012 08:57 AM |
So Cal drifting | Thefear13 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 08-10-2012 04:53 PM |
REAL drifting thread | TylerLieberman | Off-Topic Lounge [WARNING: NO POLITICS] | 20 | 02-28-2012 04:20 PM |
FT-86 II (RC) Drifting | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 11-11-2011 02:02 AM |
