05-15-2017, 04:25 PM | #141 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
The Following User Says Thank You to FRS Justin For This Useful Post: | Kris86 (05-16-2017) |
05-15-2017, 04:35 PM | #142 | |
05-21-2017, 11:35 AM | #143 |
Drives: RHD Gt86
So, after not finding anything externally, we pulled the motor :-(
Upon inspecting the rings we found they were indeed cut a bit to big, not drastically. We replaced them and cut them over correctly and have put the engine back in last night and stared her up this morning. Still, on intial cold start up it will not idle by itself, but after a while it definitely got to idle unassisted a lot quicker than before. Still doesn't sound like I've fixed the problem :-( My next step is thinking of flying in my tuner I don't know what else to do Mechanic thinks it could be tuning related
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-21-2017 at 12:10 PM. |
05-21-2017, 11:36 AM | #144 | |
Drives: RHD Gt86
We did this when we pulled the engine out, we could hear it going down into the crank case
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
05-21-2017, 11:37 AM | #145 |
Drives: RHD Gt86
NONE of the pistons had any marks on them to indicate there would be any bent valves
06-01-2017, 11:00 AM | #146 |
I Love custom Turbo kits
Drives: Limited BRZ
Anything new @Kris86 ?
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Kris86 (06-05-2017) |
06-01-2017, 11:02 AM | #147 |
Drives: Late 2014 Subaru BRZ
When you replaced the valve springs, did you lap each valve, maybe its you head and valves not seating correctly?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
The Following User Says Thank You to GsxrMe For This Useful Post: | Kris86 (06-05-2017) |
06-01-2017, 01:08 PM | #148 |
The initial startup rough idle is caused by it firing up on larger than stock port injectors. Mines done it for years, you get use to holding the throttle a bit for 20-30sec until it kink onto the direct injectors.
06-05-2017, 01:43 PM | #149 | |
Drives: RHD Gt86
Wish I knew what to say Do u know if something is wrong with Delicious Tuning? Or maybe they are just point blank avoiding me. Been trying to get in contact with them about a log I sent them since the 27th of may
06-05-2017, 01:44 PM | #150 |
Drives: RHD Gt86
Yes we made sure we did this process with precision... we made sure all valve shims were gapped correctly
06-05-2017, 01:46 PM | #151 |
Drives: RHD Gt86
Pretty sure is isn't supposed to be this bad... to me it needs more fuel at idle. Especially on cold start
06-05-2017, 01:55 PM | #152 |
Drives: 2013 Ultramarine FR-S
?? I didn't have this issue on my ID1000s. Not even on E85 in below freezing weather. Possibly tune related...
The Following User Says Thank You to DustinS For This Useful Post: | Kris86 (06-05-2017) |
06-05-2017, 02:38 PM | #153 |
Drives: Limited BRZ
Me neither but he's running 2000cc injectors, really don't know if it makes htat much of a difference.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | DustinS (06-05-2017) |
06-05-2017, 02:38 PM | #154 |
Drives: Limited BRZ
I particularly don't know. Hope you get a reply soon.
Similar Threads | ||||
Who's tired of the "Pedal Dance" and wants to be in real control of their car? | FT-86 SpeedFactory | Tracking / Autocross / HPDE / Drifting | 61 | 10-01-2015 07:44 PM |
I drive fast because the car feel "slow" | fang_gt86 | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 05-04-2015 01:06 PM |
Most effective ways to make a "fast" NA car | Kronos | Engine, Exhaust, Transmission | 68 | 02-16-2014 01:59 PM |
XSXV: Nissan R34 Skyline from "Fast and Furious" | goat_cheese | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 10-25-2012 04:15 PM |
come and hoon they say.... it will be "like Fast and the Furious", they say... | davey90 | AUSTRALIA | 5 | 10-23-2012 12:11 AM |
