05-02-2013, 07:21 PM | #141 |
The 370Z guys seem to have a lot of issues with ice mode, and most think it's due to their "Brake Assist" function which adds additional pressure during panic braking, same as our cars. Whatever it does seems to cause the ABS to kick in which reduces your braking to about 30%. Using grippier tires and more agressive brake pads just makes the problem worse. The other consistent issue is stabbing at the brakes versus more progressive braking. I think having any throttle input while braking probably causes something to freak out these days as well, due to logic added after the whole Toyota throttle sticking fiasco.
Almost all modern cars seem to have issues with this. 370Zs, Miatas, Corvettes, Mustangs, etc. and some get it and some don't so it's definitely tied to driver behavior in some ways as well. I just added some gripper front pads we'll see how things work at our next event. |
05-16-2013, 03:53 PM | #142 | |
Drives: 2013 Asphalt FR-S
On track (with 225/45 AD08's in sunny 70 degree weather) i have not experienced ice mode and i have never done the pedal dance, just the 5 second disable. I have seen flashing slip indicator under braking at AMP, especially after hitting the gators at 3 then immediately breaking for 4. (EDIT: now that i think about it, i was trailing into 4, but i think the light was comming on before turn in.. i need a go pro) I do not left foot brake, and i do tend to smoothly ramp up the pedal pressure rather than jabbing. At a drift event I experienced all kinds of weirdness with the 5 second off mode and I do think i experienced ice mode. I tried the pedal dance before one session but i don't think the car was warm enough. I think i will pull the abs fuse at the next drift event and see how that goes. Stabbing the pedal is what the ECU considers to be a panic braking maneuver.. that is just the sort of thing you do when you panic brake... lifes good, the world is a happy place, puppies make me smile, ohh ssssshhhhhiiiiiiittttttttttttttttttt im going to die..... push the pedal through the floor as hard as you can. So certainly stabbing the pedal will trigger panic mode and the brakes will probably go full on until the car comes to a stop.
~Namaste~ |
08-27-2013, 02:32 AM | #143 |
Drives: Nissan GT-R
I need to re-read this thread but I went to Balcony this weekend for a beginner drift day and I did the pedal dance for 90% of the time. I noticed when I spun out and started rolling backwards and got on the brakes to slow my roll... it pulsed the brakes and the pedal felt really rocky / spongy / ineffective. Is that ABS kicking in? It was similar to the sensation of TC kicking in when it's fully on.
I just want to know if I'm wasting my time doing this pedal dance and the 3-second hold off is what I need to do. Because it was kind of annoying to do it every time it was time for my session. Also, once in awhile my ABS light and a few other warning lights would come on. This happened to me at DDA1 as well, but it was while doing the 3-second hold only (didn't know about the pedal dance at the time). Either way, it would be awesome if either one could be a single push or default off without splicing wires. |
08-27-2013, 02:53 AM | #144 |
Drives: Nissan GT-R
Okay, so I re-read the entire thread. So my situation was I did the pedal dance. I was learning donuts / figure 8's... Of course I spun out a few times, and I'm a newbie. So before the car dies, I push the clutch in and put it in neutral while I'm trying to brake. Most of the time I was going straight back just from left over momentum. So I gently, but consistently get on the brakes and it just mushes down and vibrates / grinds.
So does this mean I need to stab the brakes harder? Not do the pedal dance? It was kind of making me feel uneasy as I progressed to get wider turns / closer to the wall and cones through the night. |
08-27-2013, 11:31 AM | #145 | |
This is pretty typical for any car. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Godzilla35 (08-31-2013) |
08-31-2013, 05:13 AM | #146 |
Drives: Nissan GT-R
do I need to re-do the pedal dance though? I did that and found that sometimes both lights were still on....?
09-04-2013, 11:20 AM | #147 |
The Following User Says Thank You to CSG Mike For This Useful Post: | Godzilla35 (09-04-2013) |
10-24-2013, 02:59 PM | #148 |
Drives: 13 White MT FR-S
What if you just unhook your ABS sensor temporarily? Maybe put a switch on it? When I busted mine traction control was permanently off as well as all braking aids seemed disabled, and cruise.
10-24-2013, 03:30 PM | #149 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I had trail braking issues during autocross runs with the pedal dance method(ice mode, pedal vibration). When I just hit the button these issues went almost completely away(mainly ABS feeling in hard braking with any amount of steering input). I did back to back runs with both to test this. I won't be using the pedal dance method anymore. As far and the traction control still being on with the button pushed, I haven't noticed the car actually do anything, saw the light flash once but I didn't feel anything as a result of it.
This only started occurring once the car got some grippy tires. On crap street tires I didn't have any issues.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
10-28-2013, 02:08 AM | #150 | |
Drives: Hydra EMS Powered FRS Raven Black
Left foot braking would only make this worse since you probably have more overlap. Thanks, Phil Grabow |
11-01-2013, 09:10 AM | #151 | |
Drives: FR-S stock for now
Thanks DougW |
11-01-2013, 09:40 AM | #152 | |
No it's not easily duplicated unless you left foot brake with overlap since most people aren't fast enough with their feet right foot braking. So if you're not experiencing it, don't even worry |
11-01-2013, 11:00 AM | #153 | |
DougW |
11-01-2013, 11:17 AM | #154 | |
I rarely left foot brake (something I need to work on), so I've never experienced this... |
Similar Threads | ||||
Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
