Old 08-26-2015, 06:50 AM   #141
smudge
Drives: Supercharged GT86
Originally Posted by Scalzo View Post
I'm not good with that shit , make a diy :O
Might have a solution, will keep you updated
smudge is offline   Reply With Quote
The Following User Says Thank You to smudge For This Useful Post:
Scalzo (08-26-2015)
Old 09-03-2015, 05:49 AM   #142
smudge
So bought this off a member on here. Extremely helpful and really quick delivery seeing as I'm in the UK!
Essentially it's a piece of carbon fibre (can be made from anything strong enough like plastic or metal) with 2 holes to be bolted onto the steering wheel hub and the other 2 to attach the cruise control stalk, as shown below
This can only be used with a quick release boss like the NRG, which is exactly what I'm getting. Will keep this thread updated with pics when the hub, boss and wheel arrive to show installation
SmartedPanda (02-10-2016)
Old 02-07-2016, 03:15 AM   #143
f-tech
f-tech's Avatar
Drives: stock
Originally Posted by 03Z33 View Post
All fixed Thanks for the assistance Nemeguero and F-R-S
The ABS and slip light were coming on because the clockspring wasn't centered. If you look at the stock steering wheel the clock spring sits at 12 O'clock when the steering wheel is straight. When I installed the WB hub with the arrow that normally indicates top/center at 12 O'clock it spun the clock spring around to 2:00 O'clock which the car doesn't like. Make sure to rotate the hub CCW until the clockspring is back at 12 O'clock to avoid this happening.
For those running the NRG hub, you will need to modify your hub to allow the stock clockspring to be retained, if you remove the clockspring the ABS and Slip lights will be on and may not function properly, this vehicle seems to use the clockspring for steering position/angle.
I have the nrg with the lights on how do k have to modified it?
f-tech is offline   Reply With Quote
Old 02-08-2016, 04:53 PM   #144
2jayzee
Drives: 2015 Scion FRS
Sparco L777 wheel in black suede with NRG version 2.5 quick release and splash short hub.
2jayzee is offline   Reply With Quote
The Following User Says Thank You to 2jayzee For This Useful Post:
Old 02-10-2016, 07:32 PM   #145
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Oem wheel that I had redone. didn't like anything aftermarket but really like em wheel size and feel.
Jive Turkey is offline   Reply With Quote
The Following 8 Users Say Thank You to Jive Turkey For This Useful Post:
Hyper4mance2k (02-10-2016), Iceman (10-03-2016), JDM4E (10-02-2016), KayC (06-25-2016), NWFRS (06-26-2016), re-animator (04-10-2018), robotickrypto86 (06-02-2016), SmartedPanda (02-10-2016)
Old 06-22-2016, 11:44 PM   #146
HachiRo
Drives: 2013 White-Out FRS
So are there hubs that can be installed without the ABS light issue coming up? Someone recommended Works, but I hear some people still get the light. Install issue? Or is there really no way around it?
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 09-30-2016, 06:19 PM   #147
nmullin11
Drives: 2013 frs
Need some help, just installed my boss short hub and have an airbag light. However I had an airbag light before because I bought the car with salvage title and front end damage. Both seatbelts locked up and driver airbag went off. Sent ecu out to get codes cleared and the seatbelts out to get rebuilt. Got everything back and installed it and still have airbag light. The orange and black plugs would not come off the airbag after it detonated so I had to cut the wires. I wired both resistors to the wires directly and still have airbag light. Any help would be appreciated. Not sure what to do next. Would the light come on because the connection is not as good as if I were plugging the pins in to the connector? Does it matter if red goes to red and black to black? What about the blue?
Edit, guess I had to put together the hvac controls because of the airbag indicator on it.
Light is off now and all is well
nmullin11 is offline   Reply With Quote
Old 10-02-2016, 03:29 AM   #148
tracerit
Drives: '13 SSM BRZ Limited 6MT
what aftermarket dash piece is that? is it alcantara or suede? looks great with the rest of the interior!
tracerit is offline   Reply With Quote
Old 10-04-2016, 08:32 PM   #149
Jive Turkey
the tuna, no crust.
everything is alantara, door cards are perforated alcantara
contact http://overland-designs.com for that panel.
The Following User Says Thank You to Jive Turkey For This Useful Post:
tracerit (10-04-2016)
Old 10-14-2016, 07:56 AM   #150
leunglambs
leunglambs's Avatar
Drives: FRS RS1
Did you need to extend the wires to get the push to start in that position?
Sent from my ONE A2005 using Tapatalk
My 2015 Scion FR-S RS1 Build Thread
http://www.ft86club.com/forums/showt...19#post2718119
leunglambs is offline   Reply With Quote
Old 10-14-2016, 02:38 PM   #151
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 10-14-2016, 03:29 PM   #152
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
Nice!
I relocated my cruise control into my steering column cover.
[ame="https://www.youtube.com/watch?v=s187aqlbJEw"]BRZ Cruise Control Relocation/Rewire - YouTube[/ame]
Spinning Sushi is offline   Reply With Quote
Old 10-20-2016, 11:07 AM   #153
Jive Turkey
the tuna, no crust.
yes. be very careful the wires are extremely thing gauge.
Old 11-06-2016, 04:35 PM   #154
FR-Z STI
so stupid me decided to buy the NRG SRK-120H (short hub) without actually realizing that this involved removing the OEM clockspring and didnt even include resistors or anything. So I am now looking to rectify this. The obvious workaround would be to buy a Works Bell hub (WB-540S) or NRG Regular Hub (SRK-125H) in which both of these will allow the clockspring to be used again. Has anyone who has tried going this route to put the OEM clockspring back in from previously removing the clockspring be successful in having the airbag light, traction control, and ABS light turn off and have the system run as normal?
FR-Z STI is offline   Reply With Quote
steering wheel controls inimitable BRZ First-Gen (2012+) -- General Topics 79 09-05-2016 12:56 AM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) -- General Topics 125 04-09-2012 08:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) -- General Topics 40 12-03-2011 10:43 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 06:17 AM
