Old 06-09-2017, 06:36 PM   #141
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
I am having a hard time finding an answer to this. I hope someone can help me out.
If I add an "high flow catted front pipe", will this get rid of the catless header smell? I won't lose any gain/mess up anything with catless header/stage 2 right?
Blue Bird is offline   Reply With Quote
Old 06-10-2017, 11:58 AM   #142
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm sure it varies, but my experience is that it won't always, at least not entirely. Cold start is the worst, it's just harder to get the cat up to operating temperature relative to one in the header.
C
The Following User Says Thank You to cjd For This Useful Post:
Blue Bird (06-11-2017)
Old 06-12-2017, 01:52 AM   #143
Dru670
Drives: 2016 Scion FR-S
I have a JRSC c38 and I just installed a flexfuel kit (still on 91oct) and 700cc injectors today. Is it safe to start the car without a re-tune just to let it idle and check for fuel leaks?
Dru670 is offline   Reply With Quote
Old 09-28-2017, 02:21 PM   #144
NicoFRS
Drives: 2015 Scion FRS
Got a question that ik is stupid. BUT how plausible is it to slap on a supercharger as my first mod and then getting a big break kit, tires+wheels, suspension, flex fuel, etc later.
I know its not advisable but with a low psi tune would it be safe to run a stock FRS with a supercharger kit?
I really want the fastest results for my build to maintain a low overall cost. See ik if i upgrade everything previously mentioned before forced induction i will be craving that power. That 30ish hp from e85 wont be enough to satisfy my craving. So why not get the supercharger first and make it the perfectly balanced car later on when i have time to save instead of making myself wait and spend a lot of money before forced induction?
Please advise, any help would be appreciated.
NicoFRS is offline   Reply With Quote
Old 09-28-2017, 04:11 PM   #145
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
There is no reason you can't go that route but you'll find yourself annoyed pretty quickly that you can't make use of the power without potentially killing yourself. That said, I actually think there is some merit in this approach in that you get the power level you want first, then build the rest of the car around that. You will waste less money this way.
That said, the car is still fun on sticky tires and aggressive brakes with the stock power level and you aren't forging any new ground so there are plenty of resources available to tell you exactly what you'll need to support the power before hand. If nothing else, get yourself stickier tires and upgraded brake pads to reduce the chance that you'll kill yourself.
Lynxis is offline   Reply With Quote
The Following 2 Users Say Thank You to Lynxis For This Useful Post:
ChristineAlexa (09-28-2017), strat61caster (09-28-2017)
Old 01-14-2018, 05:05 PM   #146
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
have not seen a 2017 here yet.
they already have better air filter
The ecu has different programming and appears to run full time closed loop fuel control and does not run rich at high rpm load (from what I've seen on usa model ecu logs)
Header is changed and intake manifold changed.
Due to stock header being better and fuelling control being better you may not see as much gains from header and tunes as you did on earlier models.
but its early days.
I have a 2017. I got my hands on a Nameless header, 3" outlet. I'm deciding between the nameless over/front pipe combo (3" to 2.5"), or JDL ultra quiet 3" with grimmspeed 3"/2.5" adapter.
Ecutek seems expensive; I might be better off OFT for this, even on a 17?
I was wondering if you had an opinion or warning here?
For intake all I have is a new tube with sound delete; I'm willing to buy the grimmspeed or other if it will help here. Either way, full foil and I'm looking for where I can get an oil pan heat shield (like the one you can get with the gruppe-s)
Thanks,
-George
GeorgeJFrick is offline   Reply With Quote
Old 01-15-2018, 06:53 AM   #147
steve99
Thanks,
-George
OFT guys have some tunes for basic mods for 2017, but the ecu logging for 2017 roms not working correctly so its difficult to work out exactly how the tune is running at present.
Ecutek will be more expensive but if you want to mod tune it will be better as logging will work correctly
Old 01-15-2018, 12:07 PM   #148
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Hey Steve, thanks for this thread. Most useful thread of all for me, it's been the basic guide I have used for all my mods and I love my car all the more because of it.
The Following User Says Thank You to guybo For This Useful Post:
steve99 (04-05-2018)
Old 03-16-2018, 10:09 PM   #149
Totalrecall
Drives: frs
I skipped most of this other than oft, catback, e85 and got bored. Was tempted to do headers but with gains total waste of money. Now thinking turbo with money already saved though... Now im thinking why not ls1 swap. It never stops .
Totalrecall is offline   Reply With Quote
Old 06-20-2018, 06:33 PM   #150
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
Shoulda got header instead of the catback. You went about things a little bassakwards.
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Old 07-20-2018, 01:47 AM   #151
BOND007_LTK
Drives: 2013 brz
Snorkel removal may not be good idea
Snorkel removal may not be good idea - see below
https://www.pointmeby.com/2016/09/15...z-frs-gt86-86/
BOND007_LTK is offline   Reply With Quote
The Following User Says Thank You to BOND007_LTK For This Useful Post:
Scala (09-08-2018)
Old 09-08-2018, 05:26 PM   #152
Scala
Drives: 2018 BRZ tS
Thanks. Never hurts to repeat it.
Scala is offline   Reply With Quote
Old 10-09-2018, 01:49 PM   #153
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
hmm. If an OFT tune with a catless stock header eliminates the cel, do I need to reinstall the O2's in the header?
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Old 10-15-2018, 01:06 AM   #154
TxDave89
Drives: 2013 FRS
You need the O2s for your ECU to know the AFR
Sent from my Pixel 2 using Tapatalk
TxDave89 is offline   Reply With Quote
Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! Simon99 BRZ First-Gen (2012+) -- General Topics 104 10-10-2016 12:45 PM
What mods next? Exhaust? Intake? Ludacrits Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2013 08:25 PM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 05:40 PM
