01-08-2024, 08:21 PM | #1751 |
Drives: K24 2014 brz
I finally got the pedal dance to work in my car. I know a lot of people just get the trac box to activate it at a button push but just in case some people are struggling and don't want to spend the extra money, I figured I would post what worked for me.
My idle was set too high (1050) so no matter how much the car warmed up it wouldn't ever be in a state to accept the inputs. Dropping it to 850 made activating pedal dance easy and consistent to start. It only needs to be below 1000 but my brake pedal causes the rpm to jump so I went lower than necessary. |
The Following 2 Users Say Thank You to moosefro For This Useful Post: | funkjaw (01-15-2024), RedReplicant (02-04-2024) |
01-12-2024, 04:13 AM | #1752 |
Drives: Whiteout track car; lava donor
The Following User Says Thank You to Four_wheel_drifts For This Useful Post: | endless_pain (01-19-2024) |
02-04-2024, 06:54 PM | #1753 |
Drives: None
If anyone was ever thinking of running something stiffer than the rubber WRX mounts that come with the kit ... don't even bother trying. Took me two minutes of run time to figure it out.
edit: Anchor 9024 is what is included in the KPower mount kit Anchor 9023 is also listed for a WRX, it is what some refer to as "STI Mounts". They're larger than the 9024 and you have to run the drivers side flipped to clear the oil pan. Probably just buy the 9024 if replacing the mounts.
The Following User Says Thank You to RedReplicant For This Useful Post: | Jdmjunkie (02-06-2024) |
02-06-2024, 05:02 PM | #1754 |
Drives: None
Going to be testing this option for the shift selector rod here soon
https://www.instagram.com/p/C2-y-FmRolc/
The Following User Says Thank You to RedReplicant For This Useful Post: | endless_pain (02-08-2024) |
03-12-2024, 10:43 AM | #1755 |
Drives: Fr-s
Maybe a bit of semi-useless info, but I was digging around a found that both the TSX and S2000 use manifold braces. This may be a moot subject if Kpower offers/switches to the balancer shaft setup.
#9 might be a second brace as well but I couldn't confirm.
The Following User Says Thank You to redlined600 For This Useful Post: | RedReplicant (03-12-2024) |
03-13-2024, 12:00 PM | #1756 | |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
This may have been buried in this thread somewhere but a homebrew brace can be made pretty easily with cheap materials.
The Following 2 Users Say Thank You to captain awesome For This Useful Post: | redlined600 (03-13-2024), RedReplicant (03-13-2024) |
03-13-2024, 01:42 PM | #1757 | |
Drives: Fr-s
The Following 4 Users Say Thank You to redlined600 For This Useful Post: |
05-12-2024, 04:22 PM | #1758 |
Drives: K24 Swapped FRS
Jumping on the forums to see if members on here can offer any knowledge or wisdom.
My car is primarily a track car running a 4Piston K24 NA engine making around 280whp and 200wtq. The issue that I've been having for a while now is when on track, and when things seemingly get hot, the clutch pedal doesn't come back up off the floor during gear shifts. And I'd have to use my foot to bring the pedal back up. I would clutch in to grab a gear, and it would be hard to move the gear lever into a gear as if the clutch wasn't fully disengaging. When I first encountered this problem last year, thinking it was air getting into the hydraulic system. I replaced the clutch master cylinder, slave cylinder with new OEM units, and stainless braided clutch line and I still am encountering the problem despite replacing all external clutch parts with new components. Have bled the clutch slave countless of times with various brake fluids (Castrol SRF, Endless RF650, Brembo 64T) I'm running the Verus clutch fork with Kpower steel flywheel and Exedy stage 1 clutch. Strangely enough, this problem only occurs when things get hot on track with repeated redline shifts, and the car shifts fine on the street after everything has cooled off. Also any tips on how to drop the transmission with the engine still in place? Seems harder to do with a K-swapped car than the stock FA20 setup. My next move is dropping the transmission to inspect all the clutch components. |
05-12-2024, 06:39 PM | #1759 |
Drives: None
I've heard of this happening before, you might find something if you search the FB group.
As far as dropping the transmission in car, it is pretty easy as long as you sufficiently clearanced the chassis so the transmission can drop down through the mounting horns on either side. Remove the slave cylinder first and then put a block of wood under the oil pan and jack up the motor to tilt it backwards. HF transmission jack is your friend.
The Following User Says Thank You to RedReplicant For This Useful Post: | zuldajin (05-12-2024) |
05-13-2024, 02:32 PM | #1760 | |
Drives: Many
The Following 2 Users Say Thank You to sfruski For This Useful Post: | endless_pain (05-16-2024), RedReplicant (05-13-2024) |
Yesterday, 09:06 PM | #1761 |
Drives: Fr-s
Clearly I missed a step, where does the primary ground go to? Just pick a spot on the block or somewhere specific?
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
