05-18-2023, 06:59 PM | #169 |
The Dictater
Drives: '13 Red Scion FRS
Ordered some Apex Arc8s in black with 35 offset this week, along with their valve stems. They are supposedly arriving Tuesday.
Now, tires. Options and thoughts below. 1. A052 in 245/40. Every review says this should be the fastest and have the best road manners. I'm pretty sure all the local competitive STX folks are on them. They are also the lightest option as a bonus. Notionally they don't handle heat well, are pretty expensive, and feel a bit numb. Supposedly does really well with more camber, and I can probably get close to 4° up front if I really wanted it. 2. RT660 in 245/40. Also reportedly very good in the dry, much sharper steering and last longer. Cheaper than other competitive options. But worse road manners, not as good wet, and nearly 20% more inertia that the equivalent A052. Tread width is list as 10" on TR, but I think that might be a mistake? 3. RT660 in 235/40. I thought this might be a sweet spot in terms of sizing for these and apparently everyone else thinks so too as it's nearly the same cost per tire as the A052. I just thought sub-9" tread width seemed appropriate for a 9" wheel considering recent test reports by TR . 4. RT660 in 235/45. Cheapest size, but increases the rolling diameter an inch, which equates to 16% greater inertia of the tire. Does it matter, probably not, but I care lol. 5. RE71RS in 245/40. Also a very good tire, also expensive. New, but reviews place it high on the list, but less grippy than the other two. Does well in rain? ... Edit: the more I look at it, the more I'm leaning towards the Bridgestones.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" Last edited by Spuds; 05-18-2023 at 08:47 PM. |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | Clipdat (05-19-2023), villainous_frx (05-19-2023) |
05-19-2023, 01:53 AM | #170 | |
Proud of BOXER
Drives: Subaru Boxer
Yeah buddy!
05-19-2023, 10:18 AM | #171 | |
Drives: Crapcan
I really don't think you can go wrong with any of those tires.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Spuds (05-19-2023), villainous_frx (05-19-2023) |
05-19-2023, 10:28 AM | #172 | |
The Dictater
Yeah, I think I'm going to order the RE71RS in 245/40R17. Tire Rack has a few promotions/rebates that reduce the final installed price quite a bit, and I think it winds up less expensive than the falkens in the same size.
Also: "Build Thread" |
The Following User Says Thank You to Spuds For This Useful Post: | NoHaveMSG (05-19-2023) |
05-19-2023, 10:33 AM | #173 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (05-19-2023) |
05-19-2023, 10:55 AM | #174 |
The Dictater
Tires are ordered. Ouch, my wallet hurts lol.
The Following 4 Users Say Thank You to Spuds For This Useful Post: |
05-19-2023, 12:18 PM | #175 |
Drives: 2013 frs base
FWIW: the stock TPS (from my 2013) won't work with the Arc8's even though their literature says they will.
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | autoracer86 (05-20-2023), Spuds (05-19-2023) |
05-19-2023, 12:47 PM | #176 |
The Dictater
Good to know, thanks! I wasn't planning on running tpms on these.
The Following User Says Thank You to Spuds For This Useful Post: | blsfrs (05-20-2023) |
05-19-2023, 11:18 PM | #177 |
The Dictater
Alrighty, on to problem that I caused myself #234: Leaking double slip joints. Yes, I bought a used PTuning header with ceramic coating and it's of course leaking at the slip joints. I would be fine if they completely sealed when hot, but at least one doesn't, specifically at the bottom. I do really like the header design though. The internet has not offered particularly good solutions IMO.
My options: A. Get a different header, this time without slip joints. B. Get some slip fit band clamps and high temp putty. C. Disassemble the headers and try to figure out what is going wrong. D. Have someone else cut off the slip joints and attempt to weld new ones on or a solid pipe in their place (which is extra difficult because of the ceramic coating). E: ?? I don't want to take them off/apart unless I have a good idea how I'm going to fix them...
05-20-2023, 12:42 AM | #178 | |
Proud of BOXER
Does PTuning themselves have any suggestions for fixing this?
05-20-2023, 10:29 AM | #179 |
The Dictater
I called them a few months ago asking for the exhaust table they offered in this post back in the day, but they seemed distinctly uninterested in helping me unless I wanted to go get a dyno tune.
https://www.ft86club.com/forums/show...7&postcount=12 I haven't paid them anything so I'm not really a customer, but it kind of put me off from becoming one. Not really into calling again asking for free support on a product they don't sell anymore.
The Following User Says Thank You to Spuds For This Useful Post: | Clipdat (05-20-2023) |
05-20-2023, 05:13 PM | #180 |
The Dictater
Not quite taller than the car, but it's getting there...
Yes, I ordered these tires yesterday. TR is fast.
05-21-2023, 10:31 PM | #181 | |
Drives: Crapcan
I’ve been unimpressed with PTuning. I had the gauge fail on my FF kit and sent it into them. Wasn’t really expecting anything but wanted to get it back to them to see if it was some kind of issue they weren’t aware of or possibly something I did. After they got it I called after a couple weeks and they were like “huh, what gauge?”
05-21-2023, 10:36 PM | #182 |
JDL 4-2-1 EL is what I would replace them with and sell these
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | Spuds (05-22-2023) |
Similar Threads | ||||
2018 Camaro SS 1LE vs Spuds' FRS | Spuds | FR-S / BRZ vs.... | 13 | 06-16-2019 10:11 PM |
FRS from Vroom - RISKY? | Cosa | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-21-2018 09:27 PM |
So my key FOB was put in the washing machine.... | Kayzer Soze | BRZ First-Gen (2012+) -- General Topics | 11 | 06-07-2013 11:43 AM |
Vroom! - This week's blipshift shirt | blipshift | Miscellaneous | 1 | 11-13-2012 10:29 PM |
