08-15-2023, 08:58 PM | #2143 |
Drives: brz 2017 hksv2
it s not the end of the world if you have -10% ltft, open loop pull seems good anyway
The Following User Says Thank You to tomm.brz For This Useful Post: | Sideways (08-16-2023) |
08-17-2023, 07:20 PM | #2144 | |
Drives: Orange GTS
08-19-2023, 05:19 AM | #2145 |
Drives: BRZ Blue MY17
Hello everyone
can anyone give me some suggestions for improvement?please 3rd gear WOT log: recorded using Tactrix(tuned using RR) HKS highflow filter;72mm TB;red intake manifold;tomei UEL header withnot cat;FP with 2res and highflow cat curious about tip-in-enrich i got all the time,even idle…… https://datazap.me/u/boundaras/log-1...&data=11-12-21 thanks~ Last edited by boundaras; 08-19-2023 at 05:33 AM. |
09-14-2023, 03:09 AM | #2146 | |
Drives: GT86
The correct tip-in is zero almost all the time and only spikes down occassionally on accelerator movement. |
09-14-2023, 09:36 PM | #2147 |
09-15-2023, 04:39 AM | #2148 |
Hello!
please tell me your impressions about the logs. It´s 2x WOT at 3rd year and a bit of gentle driving ("mix" log) Running NA with catless header, stock intake. Modified OFT tune https://datazap.me/u/jm22/20230911to...8?log=2&data=1 From what I understand - AFR @6500rmp is almost 12, should I try a bit "richer"? - AFR vs commanded AFR until 4k rpm behaves as it should? - kock is fine. Maybe too convervative? *I belive I have a exhaust leak on the gasket mid to final pipe. Would that influence somehow? |
10-21-2023, 09:03 AM | #2149 |
Drives: GT86 2013 E85
Hi,
It's an 86 from 2013, stock air filter and stock header. I'm on Wayne's rom E85, lean -2. I don't understand my IAM remains at 0.98 while my ethanol is around 80%. This is the first time that my IAM has fallen. It has always remained at 1 even with Ethanol at 65%. Does anyone have an idea? Here are two logs, one a wot and one normal. https://datazap.me/u/visclo/log-1695232857?log=0&data=1 https://datazap.me/u/visclo/log-1697888228?log=0&data=1 Thanks. |
10-21-2023, 11:47 AM | #2150 | |
under 2000rpm and over 7200rpm and sjould be good tune looks good on your car i wouldn t touch anythjng else anyway it s not a big deal 0.98 you still get basically full timing everywhere you could easily ignore specially if you are running e85 could not even be a real knock |
10-23-2023, 01:57 PM | #2151 | |
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
