Old 11-13-2014, 10:04 AM   #2143
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Originally Posted by Reaper View Post
My air filter is angled slightly down. I wonder if theirs was not?
Regardless of angle, I could see the filter holding on to enough water that when the car is started it sucks off all the liquid in to the intake.
Travisty75 is offline   Reply With Quote
Old 11-13-2014, 10:06 AM   #2144
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
That is not enough to cause this. you're talking about the water collected in between the pleats of the filter. Now if it was angled up it could have started to fill the pipe.
The Following User Says Thank You to Reaper For This Useful Post:
Travisty75 (11-13-2014)
Old 11-13-2014, 10:14 AM   #2145
Travisty75
Travisty75's Avatar
Correct, which could have been the first guys issue. Fireball has an issue of water being found in the intake and fouling the MAF, which wouldn't take much water at all.
This is all just speculation anyways.
Old 11-13-2014, 10:17 AM   #2146
Reaper
Reaper's Avatar
Drives: violent
He still said water poured out of the intercooler piping. Either way they need to figure this out. I've driving in some pretty hard rains with no issues myawlfmyself
Old 11-13-2014, 11:32 PM   #2147
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I checked all silicone couplers and everything was secure. I don't understand how that much water got in there other than it was leaking through the hood crack and onto the filter.
I'm just hoping to god I don't have any issues other than my maf sensor being fried.
I'm uploading a video of how much water came out of my intercooler. It's quite mind boggling.
I was actually trying to think of a way to shield the air filter. You know with like one of those heat shields? Except for running water. May look into it.
Like this: http://www.carid.com/spectre-air-int...otcaAlhM8P8HAQ
I contacted FBM about the issue and they had said they haven't heard of any other issues like this. So I don't know. :/
blackfireball5 is offline   Reply With Quote
Old 11-13-2014, 11:40 PM   #2148
blackfireball5
Here is the video of the water coming out of the intercooler piping. I literally pulled it off and water poured out.
[ame="https://www.youtube.com/watch?v=XQQ3e2zXo14&list=UUj4_xKd6iCs_7hmVVFIRMUA"]Water pouring out intercooler - YouTube[/ame]
Old 11-13-2014, 11:43 PM   #2149
blackfireball5
What's everyone's thoughts on these products?
http://www.knfilters.com/news/news.aspx?id=1235
or
http://www.autoanything.com/air-filt...n-hydro-shield
Old 11-14-2014, 12:22 AM   #2150
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Thats too much water to have been from the filter IMO.
Stick a piece of paper or dollar bill on the bumper then close the hood on it. Can you pull it out? If there is remotely any resistance when pulling then there isn't going to be enough water getting though there.
Food for thought...
I
know some have had problems with ice build up in intercoolers in cold climates, ford's eco boost have been having this problem as well as a ton of VW's.
VW's TSB fix was a drawing air from inside the engine bay, and a temp controled vaccum actuator system.
Ford's TSB fix is basicly a plate that covers 1/3 of the IC with a slight alteration to the cold-start tune. Basically they said the intercooler was being too efficient so by restricting airflow they were able to keep the air warmer preventing condensation. This was apparentely also caused by the cold climate combined with the EGR pumping wet exhaust gasses back into the system and the way the vehicle was driven. Apparently if you maintain a steady speed for a long period (such as a few hours a 70mph in 6th gear) or continuious airflow with a reduced load on the engine.
Just throwing it out there.
Old 11-14-2014, 12:35 AM   #2151
blackfireball5
I'll try that paper trick when I can.
I'm almost positive it came through the air filter. There was standing water on the black strip that bolts the front bumper down. It even has a slight bit of rust around where the bolts bolt down. The holes that are right there where those bolts are are right above the air filter.
I'm not just talking wet either. It was standing water sitting on that area. Like a little puddle.
Next time your car has been sitting outside during a heavy rain or storm, go out and open your hood and see if there is any water right there along that strip.
If you run your hand along that black strip while the hood is closed, you'll feel that it goes down on the left and right sides slightly. Right above where the filter sits.
I wish I could describe that better.
Old 11-14-2014, 01:06 AM   #2152
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Can someone help Blackfireball15 , I want his problem to be resolved.
Mikeez is offline   Reply With Quote
Old 11-14-2014, 01:10 AM   #2153
Mikeez
Engineering Student
Originally Posted by ben15r View Post
No clue how it happend, I was driving Saturday while it was raining but it was rain....so what. It ran fine no problems what so ever, shut down as usual idled down the driveway. Let it cool for a few seconds and then off. Didn't drive it Sunday (it poured off and on all day) then went to go to work Monday morning and it cranked over 2 Mby 3 times and stopped I hit the key again and it didn't even turn.
Got home started to pull it apart when I pulled the intake pipe off the throttle body atleast 1 qt of water ran out of it. Pulled the plugs spun the engine till it seemed all the water was out. Ran it with the charge pipe unhooked and it was knocking like crazy and there was all kinds of water coming out of the intercooler outlet pipe. It is straight water no color no smell no taste have had 3 different people agree on that.
-,- parked it Saturday it sat outside in the rain hood down and all, then the charge pipe was filled with water....
@Blackfireball15
Anyone solved these issues?
Old 11-14-2014, 01:26 AM   #2154
blackfireball5
Originally Posted by Mikeez View Post
@Blackfireball15
Sounds exactly like my story.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 11-14-2014, 01:33 AM   #2155
Mikeez
Engineering Student
I've been thinking about it... If you take an intercooler and pressure wash it. Will it accumulate the water. If yes, then the problem is obvious. If no, then either the clamps are not tighten and little water dissipated in it.
Other option, water got in the air filter through the hood cracks or from under the car.
Do you have you factory underbody?
Old 11-14-2014, 01:34 AM   #2156
blackfireball5
Yeah, i do.
Wheelwell Profile
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
