10-22-2021, 07:10 PM | #23395 |
Be Kind
Drives: 2020 86
I really wanted bulbs I could replace for less than $1000 when they go out that didnt' require bumper removal and entire lighting assembly replacement so...
10-24-2021, 04:57 AM | #23396 |
Meow
Drives: GT86, Volvo 996
What are these? I rather like them :-D
Also just curious, what did you sell the LEDs for? |
10-25-2021, 05:58 AM | #23397 | |
Be Kind
Drives: 2020 86
I didn't sell the LEDs but they do sell for a mint. I just boxed them up. I don't like the idea of having to spend $1000 usd for a new headlight if one of the LEDs fails so going with these headlights that use $20 bulbs seems like a better idea to me. The light output isn't as good but it's not so drastically different than I'm bothered by it.
10-25-2021, 02:35 PM | #23398 |
Drives: 2013 FR-S Series 10
I recently did STI engine mounts and mtec shifter springs. The mounts did tighten engine response up a smidge and did reduce oscillation when getting onto the throttle which is good, and i feel no difference in nvh.
The shifter springs totally change the feel of the shifter and made everything feel much tighter, great mod. I also have the perrin rear shifter bushing. Would adding the whiteline transmission insert be too much for a daily driver alongside the perrin bushing?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following User Says Thank You to Decep For This Useful Post: | Wally86 (10-25-2021) |
10-25-2021, 07:05 PM | #23399 |
Drives: 2015 FR-S
10-25-2021, 10:48 PM | #23400 |
I dont really have much shifter rattle before or after. Only time i get it really is when im in a lower gear, and i let off the throttle and coast at higher rpms.
Theres basically no downside to the perrin bushing imo.
The Following 2 Users Say Thank You to Decep For This Useful Post: | FrickingReallySlow (10-25-2021), Wally86 (10-26-2021) |
10-26-2021, 07:36 AM | #23401 | |
Wes
Then again, I have a 1 piece aluminum driveshaft currently, which does exacerbate the noise problem. Had to get rid of the diff bushings, it was getting to be too much and the driveshaft would vibrate as well. Edit: forgot to add that I also have the Perrin engine mounts, which have a lot more NVH than the STI units from what I'm reading here
Instagram: @gt86ws
10-26-2021, 10:02 AM | #23402 |
Drives: 17 Asphalt 86
I did notice small NVH with the whiteline bushing insert via the trans. It's pretty miniscule but it is there at certain RPM. I notice it most around 2500.
Well worth the reduction in slop. STi mount seems like a solid alternative though the cost of the insert is good bang for buck. |
10-30-2021, 03:11 AM | #23403 |
WHAT DID YOU DO TO YOUR FRS TODAY?
Replaced my Sparco L360 with a Momo Montecarlo
The retainer plate for the horn button does not sit flush with the Splash hub, so I don’t have a horn, or a horn button and it’s quite annoying. I still like the look and feel of it regardless. |
10-30-2021, 08:39 AM | #23404 |
Drives: Subaru BRZ
I am hoping that it's my eyes or my computer, but the wheel looks wonky...
The Following User Says Thank You to JD001 For This Useful Post: | Cedric (10-30-2021) |
10-30-2021, 12:30 PM | #23405 | |
2013 Series 10 FRS #553
10-30-2021, 02:17 PM | #23406 |
The Following User Says Thank You to Cedric For This Useful Post: | JD001 (10-30-2021) |
10-30-2021, 02:19 PM | #23407 |
Key bling via AliExpress to cover up my dusty key.
11-01-2021, 04:36 AM | #23408 |
Drives: 86 GT
Finally have my custom brake air deflectors up and 3D printed - very happy with the additional cooling seen in testing so far.
The Following 10 Users Say Thank You to Compelica For This Useful Post: | bcj (11-01-2021), BigHugeFatGuy (11-01-2021), Cephas (11-01-2021), jflogerzi (11-01-2021), NoHaveMSG (11-01-2021), soundman98 (11-01-2021), Spankopotomous (12-27-2021), villainous_frx (11-06-2021), Wally86 (11-01-2021), Yoshoobaroo (11-01-2021) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
