go_a_way1, MisterSheep
Old 11-01-2021, 07:59 AM   #23409
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by Compelica View Post
Finally have my custom brake air deflectors up and 3D printed - very happy with the additional cooling seen in testing so far.
That’s awesome! Can you share the 3D files in the 3D printing thread?
Old 11-01-2021, 08:10 AM   #23410
Ashikabi
Ashikabi's Avatar
Wait... What are these and how do they work
Old 11-01-2021, 08:57 AM   #23411
Compelica
Compelica's Avatar
Drives: 86 GT
These utilize the deflected air coming from the wheel deflector (starting at the shorter side of the arc) and undercarriage (via the fins) where the airflow is diverted to the brake assembly. The concept is similar to the common Porsche GT3 brake deflector mod, although this comes with some proper mounting on the lower arms instead of zipties, and fins to focus the airflow instead of escaping from the top and bottom of the deflectors.
The image below from one of the threads discussing this should give you an idea.
https://www.ft86club.com/forums/show...7&postcount=22
Unfortunately I'm currently monetizing it - hope you understand. If there's enough demand from owners overseas I can set something up.
Compelica is offline   Reply With Quote
The Following 4 Users Say Thank You to Compelica For This Useful Post:
Busybee (11-01-2021), jcw99 (11-01-2021), Kiske (11-07-2021), Yoshoobaroo (11-01-2021)
Old 11-01-2021, 09:16 AM   #23412
Yoshoobaroo
TRACKBREAD
Makes sense! Data looks good?
Old 11-01-2021, 09:51 AM   #23413
Compelica
Compelica's Avatar
Drives: 86 GT
Pretty good so far - during testing I had set up a scenario and repeated it several times as consistent as I could; in that particular scenario I would see a significant delta with one side equipped and the other without.
Though, how much cooling is obtained is going to be due to many factors, eg. how far you've driven to allow it to cool, how fast you got up to speed, time to measurement - but the results from the repeated scenarios do show a trend that the deflector is doing its job.
Some of the local guys are taking it to test on track during the next few days, will certainly be able to get some feedback from them.
The Following 3 Users Say Thank You to Compelica For This Useful Post:
Jdmjunkie (11-01-2021), Wally86 (11-01-2021), Yoshoobaroo (11-01-2021)
Old 11-01-2021, 08:36 PM   #23414
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
These look good. My car has 17x9 Apex wheels with 245/40 tires. I tried to refit the Porsche deflectors to my car. I trimmed them way down but never could get it so the tires didn't rub. If you haven't already, test fit your deflectors with aftermarket wheels and tires.
The Following User Says Thank You to blsfrs For This Useful Post:
Compelica (11-05-2021)
Old 11-01-2021, 08:49 PM   #23415
jflogerzi
jflogerzi's Avatar
There will plenty of interest if you can show data and confirm fitment
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Compelica (11-01-2021), Yoshoobaroo (11-01-2021)
Old 11-01-2021, 09:04 PM   #23416
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What material are you using?
Old 11-01-2021, 09:57 PM   #23417
Compelica
Compelica's Avatar
Drives: 86 GT
It's ABS - IMO, probably the best balance of cost and purpose when it comes to heat and exposure to the outdoors.
Old 11-01-2021, 10:33 PM   #23418
Yoshoobaroo
TRACKBREAD
Will the final version be injection modded?
Old 11-01-2021, 11:00 PM   #23419
Compelica
Compelica's Avatar
Drives: 86 GT
I have considered it but not fully explored that option - last I looked around it was prohibitively expensive for the expected demand.
However the current printed piece is very solid - I would think that I may have overengineered it in terms of structural strength (not an actual engineer) but I prefer having a larger safety factor.
The deflector is light too, about 115g for each side. Since it is sitting on the lower arm it would technically be considered as unsprung weight, though it's unlikely to be a major concern but always an advantage to maximize what's available.
The Following User Says Thank You to Compelica For This Useful Post:
Yoshoobaroo (11-02-2021)
Old 11-01-2021, 11:41 PM   #23420
Cedric
Cedric's Avatar
WHAT DID YOU DO TO YOUR FRS TODAY?
Cleaning
Cedric is offline   Reply With Quote
The Following 6 Users Say Thank You to Cedric For This Useful Post:
beltax90 (11-09-2021), JonAvalon (11-06-2021), MJones_RB (11-03-2021), new2subaru (11-02-2021), RToyo86 (11-04-2021), Wally86 (11-02-2021)
Old 11-02-2021, 01:08 AM   #23421
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
i had enabled winter mode, now i am running on snows tires.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Old 11-02-2021, 01:17 PM   #23422
buruguduy
Drives: 2013 Scion FRS
Change front wheel bearing
And wheels
buruguduy is offline   Reply With Quote
The Following 2 Users Say Thank You to buruguduy For This Useful Post:
beltax90 (11-09-2021), villainous_frx (11-06-2021)
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 10:19 PM
