04-07-2024, 02:43 PM | #24585 |
Drives: 2013 frs base
While checking my FRS over for next weekend's HPDE event at Summit Point, I found some pretty deep cracks in my right front rotor. The left didn't look too bad. I changed them both.
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | humfrz (04-08-2024), Ultramaroon (04-07-2024) |
04-07-2024, 03:35 PM | #24586 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Ouchy!
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | blsfrs (04-08-2024) |
04-07-2024, 03:56 PM | #24587 |
chicken tonight
That's impressive.
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (04-08-2024) |
04-07-2024, 05:17 PM | #24588 |
chicken tonight
Good enough. Start the clock.
04-10-2024, 05:07 AM | #24589 |
Drives: Toyota 86
Finally installed Bayson's R Trd style lip on my 2015, yes it does fit, took the chance on it.
04-11-2024, 09:49 AM | #24590 |
Drives: FR-S,GTI
Some people never learn. I rounded out the bolts holding the driver's seat down making them virtually impossible to remove by using the wrong tool The first one I drilled and removed with a medium easy-out. It wasn't easy but it worked. The torque on these bolts is unbelievable. I thought I was going to break the vice grip holding the easy-out.
The second bolt, I figured, I could do a shortcut and drill the hole smaller and use a smaller easy-out. So, of course the worst possible thing happened. The easy-out broke in the hole. I don't know what I'm going to do now. I can't believe what kind of idiot would use this fastener for this application. It's an M10 bolt with a tiny little head on it torqued down to a million ft/lbs. I hope the guy got fired and now works at the VW design department where is opinions are cherished. |
04-11-2024, 10:10 AM | #24591 | |
Drives: 2018 BRZ
There are rounded nut extractors that you should still be able to use - they look like a regular socket with a left-handed twist in them. Some penetrating oil wouldn't hurt, either. Project farm did a test on these once, he's my go-to place for recommendations - |
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | WNDSRFR (04-11-2024) |
04-11-2024, 11:20 AM | #24592 |
Drives: FR-S,GTI
It might have been torqued down to 39 ft/lbs but it takes a hell of alot more force than that to remove them. Thanks for the tip on the nut extractors. Maybe that'll do the trick. As far a penetrating oil. They've been marinading for a month.
04-11-2024, 12:09 PM | #24593 |
chicken tonight
The black oxide anti-corrosive finish is notorious for stiction. That and the wide flange are a horrible combination.
The Following User Says Thank You to Ultramaroon For This Useful Post: | WNDSRFR (04-11-2024) |
04-11-2024, 05:25 PM | #24594 |
Drives: FR-S,GTI
Outstanding description of the situation. At least they corrected the problem.
The Following User Says Thank You to WNDSRFR For This Useful Post: | Ultramaroon (04-12-2024) |
04-12-2024, 07:08 PM | #24596 |
Drives: Toyota 86
Installed Bayson R Trd style fender flare extensions today.
The Following User Says Thank You to gt86ser For This Useful Post: | overd0sed (04-12-2024) |
04-12-2024, 08:53 PM | #24597 |
AutoX-10/10ths every run
SMOG
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
04-14-2024, 05:48 PM | #24598 |
Drives: FR-S,GTI
It was such a beautiful day I washed and waxed her. Now every little dent and scratch is magnified. I had to step back and appreciate what a beautiful cool car this is. It is a classic in every way. Nothing compares to it. I get compliments all the time and can only respond with with thanks. But they're just stating the obvious, this is a cool car. It is now and always will be. I would include a picture but it just wouldn't do it justice. Now back to the meds
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post: |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
