04-08-2024, 04:04 PM | #253 |
Yay for first Gen2 MCA install photos (at least here)
Cannot stress enough to chase the existing subframe bolt with Kroil or something to clean it out. SUPER easy to cross thread and mess up everything. My existing subframe bolts were not friendly to work with. Needed multiple times of soaking the hole and threads of the existing bolt and running it back and forth to clean up threads. MCA’s install guide says to bolt first to the existing trailer arm location THEN bolt to subframe. I worked backwards. I don’t see what I’d want to create tension on the subframe bolt and increase chances of cross threading. IMO worked out great. And as you can see, still requires more effort to center that hole. Don’t fully secure down the subframe bolt until you have the other trailing arm bolt located, but yeah, you get the picture Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following 6 Users Say Thank You to M0nk3y For This Useful Post: | autoracer86 (04-08-2024), Compelica (04-10-2024), norcalpb (04-08-2024), RToyo86 (04-08-2024), Tatsu333 (04-08-2024), whataboutbob (04-13-2024) |
04-08-2024, 04:48 PM | #254 |
Drives: Toyota GT86
Did you use factory tq settings for the new bolts supplied or does Mca provide new specs ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-08-2024, 04:54 PM | #255 | |
New supplied bolt for the subframe is spec’d at 107 ft-lbs by MCA. Then they recommend the other (2) bolts that go in the existing trailing arm and spacer to be torqued to existing OEM Spec (87 ft-lbs). Make sure you torque the bushing while loaded on the ground Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | autoracer86 (04-08-2024) |
04-08-2024, 09:27 PM | #256 |
Drives: 17 Asphalt 86
Noted with subframe bolt. I usually hit bolts with the drill brush to clean up junk but blasting subframe hole is a good idea.
04-10-2024, 06:16 AM | #257 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Wait until my Flex capacitor hits 88
04-10-2024, 08:26 AM | #258 |
Yup, it's honestly a night and day difference and truthfully I'm amazed I went this long without any sort of trailing arm correction
FWIW, I have MCS 2Way Remotes, 9k/11k, it's not compromised suspension by any means. I would say the most immediate impact was the elimination of the "pogo" effect off large bumps or dips in the road. The rear just simply feels more in sync with what the front was doing. First track even April 25th, I made a ton of changes to the car, but I'm sure I'll be able to see what this is doing to help. FWIW I have STi Trailing Arms on the way as well
Kyle H. - #89 STX
The Following 6 Users Say Thank You to M0nk3y For This Useful Post: | gen3v8 (04-10-2024), kevaughan (04-25-2024), norcalpb (04-10-2024), RToyo86 (04-10-2024), strat61caster (04-10-2024), whataboutbob (04-10-2024) |
04-10-2024, 12:22 PM | #259 |
Drives: 2020 BRZ Sport Tech RS
FYI for anyone with the first generation (or just wondering what the difference is), I emailed MCA to ask for details on the differences and whether there would be any reason to upgrade, and here was their (very prompt) response:
"There is nothing functionally different, just a few minor design improvements. The main one being a rubber bush assembly that allows for some additional movement between the cross-member and the chassis. Overall, this is a better and more refined product but we wouldn’t say it is critical to upgrade."
The Following 8 Users Say Thank You to Tatsu333 For This Useful Post: | autoracer86 (04-11-2024), endless_pain (05-16-2024), gen3v8 (04-10-2024), kevaughan (04-25-2024), Ohio Enthusiast (04-10-2024), Racecomp Engineering (04-13-2024), RToyo86 (04-11-2024), whataboutbob (04-11-2024) |
04-13-2024, 12:59 AM | #260 |
Fast shipping!
Mine arrived today, they're very generous with their swag too! 8 stickers and a jet tag. Thanks McA! Now just waiting on trailing arm to install everything together. Last edited by RToyo86; 04-13-2024 at 01:38 AM. |
The Following 7 Users Say Thank You to RToyo86 For This Useful Post: | autoracer86 (04-13-2024), DustinS (04-13-2024), kevaughan (04-16-2024), norcalpb (04-15-2024), Racecomp Engineering (04-13-2024), Tatsu333 (04-15-2024), whataboutbob (04-13-2024) |
04-15-2024, 02:08 AM | #261 |
Ordered mine on Monday and they arrived Thursday. I fitted them today and test drove it briefly with a full tank. All my whiteline bushes made fitting tight. The car still has easy wheelspin power but it doesn`t snap sideways so aggressively now. I`ll be taking it to the mountain twisties tomorrow for a better shakedown.
The Following 3 Users Say Thank You to gen3v8 For This Useful Post: |
04-25-2024, 06:22 PM | #262 |
Parts installed, just getting alignment done now
The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
04-25-2024, 06:28 PM | #263 |
Drives: Toyota GT86
Sweet. Keep us updated
04-25-2024, 09:53 PM | #264 |
Drives: 2018 BRZ
I'll share my experience with the GP Sport mod on my BRZ. Fairly straightforward to install, both the relocating piece and the solid bushing insert in the rear of the subframe. I did one corner at a time and didn't support the subframe. The biggest pain was the parking brake cable bracket, which just didn't want to align with the cutout when tightening the small bolt holding it.
I had the Whiteline rear subframe inserts (KDT922) already installed on the car. Both the relocating piece and the solid insert have the same shape as the bottom Whiteline insert and they fit the same in the subframe bushing. I left the top part of the subframe inserts in place and didn't notice too much of a difference in that regard. After installation, it looks like the rear lowered by about 5-8 mm. Sadly I didn't measure before and after, and it's estimated by look and older measurements. My best gauge for the lowering is that a speed bump at my kid's school which used to scrape at the rear only rarely, now scrapes all the time unless I take the opposite lane which is lower. For driving impressions, I didn't have the chance to go on a track or autocross, but I did drive it in anger on some of the roads I'm very familiar with and continued to lightly oversteer on some specific corners in my daily drives. First, the rear feels more comfortable over bumps and dips, especially sharp ones. Second, it's harder to break traction in the dry, in a similar way that moving from the OEM Primacy tires to UHP/Max tires was. I need to be very deliberate in most corners to get oversteer that really requires counter steering to correct. Less deliberate application of throttle causes noticeable rotation but no need for counter steering. I.e. still feel the RWD working. When the car does oversteer, it's mostly gentler and less snappy. Accelerating in a straight line, it's also harder to spin the wheels in 1st or get a chirp in the 1st to 2nd upshift. Finally, in the wet the car has quite an interesting character - instead of wheel hop the rear tires slide more, causing the rear to step out more easily, and it takes more time for the rear to regain traction. This is mostly the case when accelerating in a straight line, where before the mod being aggressive off the line from a red light (with painted lines and worn intersection asphalt) the rear would hop and spin but letting off the gas would regain traction. Now the rear would slip and slide around and letting off the gas needs to be a second or two longer before I can apply throttle again. When turning it's a similar story, with more grip that turns into even more controllable slides. Overall I'm happy with this mod, if anything just for the sake of the variety in driving experience after 4 years with the BRZ. I'm still undecided if the daily fun-factor was increased or reduced, and I plan on doing a couple of track days and some back road trips to more fully explore the car with the mod. |
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
04-26-2024, 12:52 AM | #265 |
Enigmeerkat
Drives: 2015 Toyota 86 GTS
Sorry for the noob question, but I have a Gen 1 with stock suspension except for Whiteline Swaybars. Would this upgrade still be relevant for my setup? Or does it better suit cars with coilovers?
2015 Toyota 86 GTS - Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch - PSR UEL Header, Invidia R400 Catback - Whiteline Swaybars, 18" ROH Blue Evo R |
04-26-2024, 03:23 AM | #266 | |
Drives: Toyota GT86
As you can see in the post above some users have noticed a drop in rear ride height after install so you might have a bit of negative rake which is probably a good thing performance wise but you might not like the look of the rear being lower than the front.
Similar Threads | ||||
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
"Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 02:49 PM |
"Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
