Old 01-22-2016, 05:48 PM   #15
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
It's the spring perch on the strut that you'll rub, not the coil itself. And no, not any bigger in diameter.
Toyarzee is offline   Reply With Quote
Old 01-22-2016, 11:16 PM   #16
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Originally Posted by Benschneider06 View Post
So I have 17x9 +35mm Enkie RPF1's in my cart with 245/40/17 Pilot Super Sports to wrap them in my cart. My car is lowered 1"
I've someone reassure me it will fit & someone tell me it won't fit without coils...
Anyone want to chime in before I buy a setup that doesn't fit?
I had same wheels, same springs, same tires, and it fit fine. No rubing. Plus camber was set at -1.2 front and -1.5 rear.
eSOLOR is offline   Reply With Quote
Old 01-23-2016, 01:50 AM   #17
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
There you have it
/thread
KevinK121 is offline   Reply With Quote
Old 01-23-2016, 08:36 AM   #18
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno Edition
For autox last year I ran a set of RPF1's 17x9 +35 with 255/40/17 Hankook RS3 lowered with swift spec r springs. I would only rub at full lock while reversing out of my driveway. It was rubbing on the inside frame not the shock. Otherwise no rub and no issues. Going with a set of 245/40/17 will be fine.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
rcm47 (04-11-2017)
Old 03-14-2016, 05:13 AM   #19
Davesta619
Drives: Brz
I too want to get 17x9 wheels on my eibach pro kit. Sadly they only offer it in +42. Anyone know if I'll have any problems with rubbing or anything
Davesta619 is offline   Reply With Quote
Old 03-14-2016, 10:42 AM   #20
KevinK121
Miata traitor
KevinK121's Avatar
+42 would bring the wheel in more than +35. You'd worry about rubbing on the springs over the fender in that case.
Fortunately though, you could use some spacers to move the wheels out a bit. Shouldnt need more than 10mm.
Id imagine this combo is probably described on here somewhere.
Sold the BRZ and bought a miata O_o
Old 03-15-2016, 12:32 PM   #21
Shneegle
Shneegle's Avatar
You can find 17x9 +35 here.
Old 04-11-2017, 01:03 AM   #22
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I've been looking for this answer for like weeks! I have the same exact wheel and tire set up and thought about running the same springs but with bilstein shocks. How much camber were you running up front and how were you able to achieve it? Are you still running this set up? And how satisfied are you with it?
rcm47 is offline   Reply With Quote
Old 04-11-2017, 01:21 AM   #23
Shneegle
Shneegle's Avatar
I was running around -2 degrees just using camber bolts. It worked well for that season but just wasn't as competitive. I would imagine with bilstein shocks it would be pretty awesome.
I moved up to a set of Fortune Auto 500's that I got cheap. Spent a year on those and had them rebuilt and upgraded to 510's.
rcm47 (04-11-2017)
Old 04-11-2017, 06:30 AM   #24
rcm47
rcm47's Avatar
So with -2 up front there was no rub at all on the spring or spring perch? Would you also happen to have a picture of your car in this set up that isn't an action photo? Thanks!
Old 04-11-2017, 08:31 AM   #25
dattran86
Driver
Drives: 2013 Whiteout FRS
Im running 235/45 on 17x9 35 RPF1s right now, with a -2 camber up front. it close to the struts atm, if i decide to run a 245s i think it might rub slightly on the struts. you can always throw on a 3mm spacer which is "safe" to run on oem studs if you experiencing any rubbing.
dattran86 is offline   Reply With Quote
Old 04-12-2017, 07:20 AM   #26
Shneegle
Shneegle's Avatar
Here are a few that are not action pics. Looking up the camber bolts it was probably closer to -1.7 than -2.
rcm47 (04-12-2017)
Old 04-12-2017, 08:24 AM   #27
rcm47
rcm47's Avatar
@Shneegle thanks, that looks great! So this was just springs, camber bolts, and adjustable rear LCAs?
Old 02-22-2018, 09:29 AM   #28
kpamir
Drives: 2015 halo white fr-s
I recently moved and have to raise my car a bit, I am on HSD coils and they have unfortunately seized up hard.
My cheapest option is to put the stock struts in, but I do want that slight drop so Ill be getting the trd lowering springs.
I am running rpf1 17x9 +35 on 245/40/17 mpss. I am seeing that a couple of the guys here have that set up and it works fine with the 1" drop from the trd lowering springs.
Just to confirm before i make the purchase are the camber bolts necessary for the fitment ? Or was that installed because you wanted that slight tuck in for the wheels?
Thanks!
kpamir is offline   Reply With Quote
fitment, offset, rubbing, tires, wheels
17x9.5 +15 fitment Matty-T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-02-2015 06:26 AM
17x9 6UL - FT86 fitment available soon Guillaume Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 02-17-2015 11:54 AM
RPF1 Fitment pf330ci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-25-2014 10:07 PM
used RPF1 17x9 +35 or new Rota RT5 17x9 +42 Roadcone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-12-2014 01:16 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
