Old 04-18-2017, 04:27 PM   #15
electrongeek
Drives: 2016 Scion FRS
Originally Posted by JT.86 View Post
Japanese gt86 doesn't have drl/highbeam as same bulb right? Or is everything the same as frs except led drl strip?
Sent from my ONEPLUS A3000 using Tapatalk
The HID version doesn't have a DRL/high beam bulb. It uses a bi-xenon set up like the US Monogram headlights.
electrongeek is offline   Reply With Quote
Old 04-18-2017, 04:29 PM   #16
JT.86
Drives: Scion FRS 2016
I'm not familiar with monogram lights, so same as valenti?
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
Old 04-18-2017, 04:33 PM   #17
electrongeek
They're the same in the sense that they both use bi-xenon projectors, both low beam and high beam are from the same bulb.
I'll look into the repin method and see if it works. I wish some of the people who have successfully installed Valentis would chime in.
The Following User Says Thank You to electrongeek For This Useful Post:
JT.86 (04-18-2017)
Old 06-14-2017, 02:36 AM   #18
electrongeek
JT.86 Do you know what the white wire sticking out of the headlight is for? I've figured out all of the functions of the 8 pins in the socket, but I'm down to that last separate white wire.
I'm guessing it has something to do with the turn signals since that's the only function left that I haven't traced.
Old 06-14-2017, 10:59 AM   #19
JT.86
The white wire that's in a bullet connector is the same white wire in the harness connector. They're both for the DRL LEDs. I didn't wire it.
My DRL doesn't work though... at least in Auto mode. When I switch the stalk to DRL, my brows and led light at the same time.
___________________
Old 06-14-2017, 11:49 AM   #20
electrongeek
Does your turn signals work? Do you know which wires are for the turn signals?
Old 06-14-2017, 12:07 PM   #21
JT.86
Should be brown
___________________
The Following User Says Thank You to JT.86 For This Useful Post:
Rican_D (07-25-2017)
Old 06-14-2017, 12:25 PM   #22
electrongeek
On mine, I believe the brown and green powers up the eyebrow. White and orange powers up the DRL. I wasn't able to get my turn signals to function.
Old 06-14-2017, 02:06 PM   #23
JT.86
yeah you're right, brown and green was connected to the two remaining pins on the car side (ones that does come with any pins). white (pin2) is for positive DRL LEDs, orange is positive for turn signal.
___________________
Old 06-14-2017, 04:09 PM   #24
electrongeek
Thanks for the help. I'll fiddle around with it some more tonight.
Old 06-14-2017, 04:18 PM   #25
JT.86
let me know what you end up doing with DRL wiring. I removed the DRL resister and that's it. Didn't wire anything from that connector to the lights. Probably why my DRL doesn't automatically light up during the day.
For signal (OJ) i tapped it to one of the wires of the blinker, and the LED (white) to another wire of the blinker.
___________________
electrongeek (06-14-2017)
Old 06-14-2017, 11:37 PM   #26
electrongeek
Ok I'm struggling once again. My orange (-) and white (+) when connected lights up the white leds above the turn signals.
My green (-) and brown (+) lights up the eyebrows. I'm bench testing off of a portable 12v source and not directly off of my car so I'm wondering if that's the issue. I don't see why it would, but I'm stumped.
If it's not too much trouble could you please confirm the wiring on the turn signals? Thanks
Old 06-14-2017, 11:42 PM   #27
electrongeek
I also tried connecting your way with orange being (+) and white being (-) but that did nothing.
Old 06-15-2017, 12:01 AM   #28
JT.86
I'll do a write up of what my pins are tomorrow
___________________
electrongeek (06-15-2017)
BRZ Headlight pin/wiring diagram 2SeeKU Electronics | Audio | NAV | Infotainment 12 06-28-2020 02:17 AM
WTB BRZ OEM headlight ballasts and wiring Hot Wheels Want-To-Buy Requests 0 05-15-2016 04:51 PM
headlight wiring problem VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 0 12-30-2014 02:41 AM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 10:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
