Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
06-17-2017, 01:07 AM | #15 | |
My Primacies were toast and noisy as hell so maybe that is why I noticed more difference. I have found that they get a tiny bit bouncy after a long haul in very hot weather but it isn't horrid. After a coup,e of thousand kilometres I still think they are the best tires I have ever used on a car.
06-17-2017, 09:42 AM | #16 | |
Drives: 2013 Subaru BRZ
Pirelli used the same method when designing its high performance winter tire and the high performance all season tire. The carcass is basically same. If you drive where ambient temperatures are routinely warm, 20C or more, then summer tires will deliver better performance. As it gets cooler the high performance all season is now the better choice. Five years ago that was not the case. One interesting aspect of the new Michelin all season 3 is the relative low density of siping. To help compensate for this the grooves are molded with a micro saw tooth pattern internal to the tread grooves. For a high performance tire with so little siping the performance in light snow is remarkably good. Not so good on ice. Pirelli apparently decided in favour of better warm weather performance and less competence on snow or ice, based on the tire rack comparison test. My next set of "summer tires " will likely be those Pirellis as I run winters for winter. |
The Following User Says Thank You to Gforce For This Useful Post: | chaoskaze (06-18-2017) |
06-22-2017, 11:17 AM | #17 | |
Drives: 2013 ARGENTO A/T
Also how many miles can I expect from the as3? |
06-22-2017, 01:18 PM | #18 | |
Plus Michelin gets the compound pliability using their newer Helios compound (in French it is huile de tournesol) vegetable oil apparently makes rubber softer stronger at the same time. Nokian discovered the same effect from canola oil. Sumitomo Tire (Dunlop outside the US) made the initial discovery. Under some ambient temperature conditions the A/S3 is actually a better performer. Don't worry about miles. Worry about age. After four years all tires deteriorate noticeably. After 6 years all tires are junk. After seven years you're taking chances with your life. So, rarely will your tires wear out before they need changing anyway. Bonus if you buy brand new from Michelin, they say their latest Helios compound is so tough Michelin estimates their tires will age out first. |
06-22-2017, 03:25 PM | #19 | |
Edit: You guys have me sold on these tires now. On tire rack there are 4 different sets of AS3s though..any reason not to go for the closeout price? https://m.tirerack.com/tires/TireSea...ceFilter=400#0 Also why not consider the premier AS? Last edited by Spacemane969; 06-22-2017 at 06:17 PM. |
06-22-2017, 08:04 PM | #20 | |
Drives: 2019 BMW ///M4
You can expect 45k miles.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
06-22-2017, 09:02 PM | #21 | |
The tires we have been referencing are the Pilot AS3 PLUS. That Plus is important since the AS3s are an older tech and not nearly as good a tire (according to reviews I have no first hand knowledge of the 3). Don't get the wrong ones by accident.
06-23-2017, 12:38 PM | #22 | ||
Drives: Dodge Patitas
However, I think I may try the AS3+ soon as maybe, maybe enjoy a more civil ride... Or, completely waste the remaining thread on the PSS during a track event? |
06-23-2017, 02:34 PM | #23 | |
06-23-2017, 02:41 PM | #24 |
Not "floppy" but they do loosen up just a bit. They are no where near as bad as other AS tires I have used in the heat since they are indeed a UHP tire. The AS compromise is not bad but still there. Don't think you will take much of a hit for even heavy street driving but I would not use them myself if I was tracking where it gets really hot.
The Following User Says Thank You to Tcoat For This Useful Post: | Spacemane969 (06-23-2017) |
06-23-2017, 04:18 PM | #25 | |
The AS3+ is a more complaint ride. If you're die-hard performance than the MPSS is for you. But i think they're stopping the MPSS line.
N1rve
11-26-2017, 10:57 PM | #26 |
Drives: 2013 BRZ Sport-tech WRB
Little update, since I've just recently taken these off and put my winter tires on.
- Noticing a very slight decrease in fuel economy - After using them for a while, running them in, and switching to my winter tires, I can definitely say these are much quieter than the Primacies were. People I talk to using bluetooth noticed right away when I put the AS3+ on. - Significant increase in overall grip compared to Primacies (as a daily street tire, not sure about track). - Track better on the highway than the Primacies did. I never used to feel that I was taking a huge performance hit when I'd switch my Primacies out for X-ices, but this year was different having the AS3+. I should've waited a few more weeks. The AS3+ were still perfectly happy at the temperatures we are seeing on the east coast, and my winters are running too hot right now. Now onto winter #5 for my Michelin X-Ice Xi3's. |
Similar Threads | ||||
Improving Steering Feel | sittinSideways | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 08-18-2014 06:52 PM |
Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 04:52 PM |
Steering feel with wider tires? | TSY | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 07-26-2013 10:32 AM |
Best Tire for Steering Feel | Khyron686 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 03-12-2013 12:01 PM |
Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) -- General Topics | 8 | 12-08-2011 11:16 AM |
