Old 02-16-2018, 02:16 PM   #15
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Or never, ever even see the inside of an aircraft much less fly around in one.
"Flight" surgeon is more of a position title then a job description.
I know what a Flight Surgeon is and does, and that he will have a flight suit, and wear it on occasion going about his assigned duties, and at some point will most certainly be on flight status. Canada might be different.
Then again, it is the AF, so who knows these days.
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Tcoat (02-16-2018)
Old 02-16-2018, 02:25 PM   #16
Well my info is sort of dated but spending much time on air bases for both countries I don't think I ever saw a Flight Surgeon in a flight suit. Maybe they do now or at least when deployed.
Old 02-16-2018, 02:33 PM   #17
humfrz
Wiki says:
"Flight surgeons are typically rated aviators on flight status (i.e., they log flight hours in military aircraft as a crewmember), but are not required to be rated or licensed pilots, naval flight officers, or navigators/CSOs."
humfrz
Tcoat (02-16-2018)
Old 02-16-2018, 02:35 PM   #18
Wiki says:
humfrz
Well there we go then!
humfrz (02-16-2018)
Old 02-16-2018, 02:47 PM   #19
humfrz
My family physician is a LTC in the USAFR and is designated as a flight surgeon (so a plaque on the wall of his office says).
I once saw him at McChord AFB, dressed in a flight suit, while attending the promotion ceremonies for a General Officer, that was my client.
He used to give me some "good" meds, just to have on hand, for when I felt poorly ...... he can't do that so much anymore ......
Time to go ....... sneak up on a bowl of oatmeal .....
humfrz
Tcoat (02-16-2018)
Old 02-16-2018, 02:49 PM   #20
humfrz
I must just have always been away from the aircraft when they went out. Not like I fueled every single one that took off (although it did seem like it some days)
humfrz (02-16-2018)
Old 02-16-2018, 08:31 PM   #21
g e
Originally Posted by The owl Talon View Post
I'm studying kinesiology, then going to med school to become a flight surgeon in the USAF. Should be fun.
I bet you can find something faster than a BRZ/FRS at USAF.
Feed the speed monkey there.
And best of luck on your path!
g e is offline   Reply With Quote
Old 12-13-2018, 01:45 PM   #22
assbox
assbox's Avatar
Drives: Whiteout FRS
Theres a DIY on how to make your own buttons to retain the cruise control functionality. See YouTube link below.
[ame]https://www.youtube.com/watch?v=cvRjyI2SDc0[/ame]
IG: ft86carbon
assbox is offline   Reply With Quote
Old 12-13-2018, 06:16 PM   #23
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by JustSomeGuy View Post
as cool as aftermarket steering wheels are and considering its your daily i would just get one of those cooler oem wheels from various vendors. probably end up cheaper and would contain cruise control and an airbag
I put a Custco (spelling?) on mine and find it's a major improvement over OEM. Cruise control lever remains in place.
Qwimby1 is offline   Reply With Quote
sparco, steering wheel
Cruise Control with Aftermarket Steering Wheel **SOLUTION** pleong Electronics | Audio | NAV | Infotainment 13 07-04-2023 07:31 PM
Cruise control bracket for aftermarket steering wheel rx3 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-08-2021 12:26 AM
How do you keep cruise control with aftermarket steering wheel??? kylefrs Cosmetic Modification (Interior/Exterior/Lighting) 32 04-06-2016 05:58 AM
Cruise Control with Aftermarket Steering Wheel **SOLUTION** pleong Cosmetic Modification (Interior/Exterior/Lighting) 7 10-06-2015 07:41 PM
How do you keep cruise control after installing a aftermarket hub and steering wheel? Timtamtt Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2013 07:17 AM
