Old 08-28-2019, 10:56 AM   #15
humaN
Still tinkering with car, undecided. As for the dealer once again it's a special circumstance.
As for @86TOYO2k17
no data logs,
50 and on 3rd startup,
yes,
no,
yes,
yes,
yes thats accessible,
doing that tonight,
not sure this is first time hearing about it,
and no
humaN is offline   Reply With Quote
Old 08-28-2019, 01:11 PM   #16
86TOYO2k17
Drives: 2017 toyota 86
As for @86TOYO2k17
no data logs,
yes,
no,
yes,
yes,
doing that tonight,
and no
A data log would be the best place to start after smoke testing, as it will be able to really narrow down the issue, and helps tremendously to tell if its tune related, or mechanically related.
as for the mileage and startup, I bet the CELs where already on, but got erased and took 50miles / 3 drives to pop back up, could even test it by erasing them and seeing how many miles/drives to re-pop up.
A boost gauge and or aftermarket MAP sensor could help make sure you are making the expected amount of boost, and don't have a boost leak someplace. If stock MAP sensor can only read to about 6PSI if aftermarket MAP it needs to be re-scaled to work properly but can read to much higher depending on BAR.
Old 08-28-2019, 04:56 PM   #17
humaN
Trying to find access to a data logger now, smoke test still happening to hopefully remove vacuum leak suspicions.
Car ran the same right after fix so yes CEL was off but car was still acting up.
It's running a Bosch MAP sensor so no idea if it's good enough.
Called Edlebrock again and they stated possible ECU Reflash needed due to having to run lean for so long with Bypass actuator faliure
Old 08-28-2019, 05:18 PM   #18
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
F that noise.
I wouldn't keep someone elses's screwup.
If it wasn't done properly to begin with I wouldn't touch it.
Sasquachulator is online now   Reply With Quote
The Following User Says Thank You to Sasquachulator For This Useful Post:
Busybee (08-28-2019)
Old 08-30-2019, 12:00 AM   #19
humaN
Update:
Kept car,
Next step replacing IACV(looks like whole TB)
The Following User Says Thank You to humaN For This Useful Post:
Busybee (09-01-2019)
check engine light, diagnostic, forced induction, idle
Rev bounce 2013 Brz ArchReactor86 Engine, Exhaust, Transmission 5 06-19-2019 05:33 PM
Rear Passenger wheel bounce during cornering Takumidesh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-29-2019 02:34 PM
Super loud chirping noise when driving and idle Diegov Issues | Warranty | Recalls / TSB 36 08-30-2018 07:52 PM
Help! Slight vertical bounce with new wheels/tires SilverTipp Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-06-2015 11:48 AM
Idle issue when driving carlossanchez89 Software Tuning 1 02-16-2014 12:52 PM
