Old 04-16-2024, 06:49 AM   #15
Rasheid
Drives: nothing
The codes you're seeing are definitely related to emissions. P0455 is about a large evaporative emission system leak (like a loose or faulty gas cap, or a broken evap hose), P2096 suggests the car is running too lean (this could be due to issues like a vacuum leak, exhaust leak, or problems with the oxygen sensors), and P0441 indicates a problem with the evaporative emission system purge flow.
Here's what I'd recommend:
Make sure the gas cap it's on tight and in good condition. If it looks old or worn, replacing it can be a quick and cheap fix.
Check for any obvious leaks in the vacuum lines and hoses around the engine. You might also want to check around the fuel tank and charcoal canister area for any signs of damage or loose connections.
Considering the P2096 code, checking the oxygen sensors could help. If they're faulty, they could be sending the wrong data, making the car run lean.
As a refference, you might search for causes and solutions on this trouble codes blog.
Rasheid is offline   Reply With Quote
8 Codes... danielf54 Issues | Warranty | Recalls / TSB 6 09-09-2019 01:20 PM
CEL trouble steelheart100 Issues | Warranty | Recalls / TSB 9 04-18-2018 04:24 PM
What is this? Knocking Popping Tapping noise from the engine bay no codes arren123 Engine, Exhaust, Transmission 49 01-11-2018 09:18 AM
Several DTC codes ryan.moring Issues | Warranty | Recalls / TSB 5 06-05-2017 07:26 PM
Trouble Codes and Reduced Power Apex_BRZ Issues | Warranty | Recalls / TSB 5 06-21-2014 11:34 AM
