Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
04-29-2021, 12:33 PM | #15 |
Be Kind
Drives: 2020 86
No clue LOL. I'm sure someone will chime in with it. I'm afraid the answer will be throw out bearing but we'll see.
04-29-2021, 12:46 PM | #16 |
Yeah - I'm back to thinking TOB. Unfortunately it's a known weak point on the earlier cars.
04-29-2021, 02:48 PM | #17 |
chicken tonight
It's a weak point on all of 'em. Does the sound change when you tap the clutch pedal?
Not brakes. Periodicity is too high. Sounds like the driveshaft is rubbing on something.
04-29-2021, 05:59 PM | #18 | |
Drives: 2014 Scion FRS
plus i already replaced the clutch and TOB about 20k miles ago |
04-29-2021, 06:36 PM | #19 |
Drives: 2013 pearl white FR-S
04-29-2021, 07:03 PM | #20 | |
chicken tonight
I didn't think it sounds like TOB. Engine braking is key. It sounds more like thin sheet metal rub/vibe. Engine/trans, all of it forward of the mid-pipe (articulating donut gasket thingy) tweaks a little bit under torque. I'd poke around there looking for something loose.
04-29-2021, 07:17 PM | #21 | |
11-03-2022, 10:50 PM | #22 |
Drives: 2015 midnight blue limited edition.
Any luck finding out what this was ? I have basically had the same ever since I replaced the OEM TOB with a stage 1 exedy clutch. I have noise while engining braking in the 5th, a little less in 4th and least in 1st. Goes away in neutral
11-04-2022, 06:58 AM | #23 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Last Activity: 05-03-2021 06:48 AM Think your SOL asking them. |
The Following User Says Thank You to x808drifter For This Useful Post: | Tcoat (11-04-2022) |
Tags |
brakes, clutch, grinding, noise |
Similar Threads | ||||
Noise on deceleration and taking off in 1st | Dububster | Engine, Exhaust, Transmission | 7 | 10-06-2020 06:24 PM |
Weird noise | j_ros94 | BRZ First-Gen (2012+) -- General Topics | 0 | 02-26-2020 01:40 PM |
Weird Noise | FloridaBRZ | BRZ First-Gen (2012+) -- General Topics | 7 | 04-25-2014 08:35 PM |
Weird Noise??? | caradd | Issues | Warranty | Recalls / TSB | 3 | 11-01-2013 11:42 PM |
Odd noise on deceleration | Dipstik-sportech | Engine, Exhaust, Transmission | 7 | 08-18-2013 10:42 AM |
