Old 06-23-2021, 05:31 PM   #15
Escher
Escher's Avatar
Drives: 2015 FR-S
Coil packs and heat do not play well together.
How hot is it there now?
The SC shouldn't cause that much heat but if you are running an unshielded header...
We have a winner: Las Vegas, NV. Breaking records. 122° on the dash hit for a week solid.
Any way to easily ID which pack is failing?
2015 FR-S - Jackson Racing C30 Supercharger - 17x8 White Vors TR4 5x100 35 - Firestone Firehawk Indy 500 (17x7.5) - Remark Axleback Muffler Delete
Escher is offline   Reply With Quote
Old 06-23-2021, 05:35 PM   #16
Swap some around and see which doesn't work
Old 06-23-2021, 06:56 PM   #17
SexyPirates
SexyPirates's Avatar
Do you have an oil cooler? Purely curious.
SexyPirates is offline   Reply With Quote
Old 06-23-2021, 07:00 PM   #18
Escher
Escher's Avatar
Drives: 2015 FR-S
Ah was hoping to avoid the guess and check procedure, good copy though.
That's a negative. I was keeping an eye on oil temps when temps were hovering around 100 and I was never breaking 245, even with combos of very spirited driving highway + stop and go traffic to stress it and try to see how high it would go.
As I understand, 260 is the danger mark, but correct me if I'm wrong there.
Wasn't planning on installing an oil cooler until I converted it to a dedicated track car.
The Following User Says Thank You to Escher For This Useful Post:
SexyPirates (06-23-2021)
Old 06-23-2021, 08:52 PM   #19
jflogerzi
jflogerzi's Avatar
The code should tell you which cylinder is causing the misfire which then will tell you which coil pack to replace
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Tcoat (06-24-2021)
Old 06-23-2021, 09:30 PM   #20
Escher
Escher's Avatar
Drives: 2015 FR-S
Not getting a misfire code, or any code besides a bank 1 rich, which *could* help narrow it down to cylinder 1 or 3 assuming it's related. Cylinder 3 was the actual misfire before I swapped the plugs last time so it may just be the hottest cylinder.
Old 06-24-2021, 02:38 AM   #21
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Oil cooler won't help overheated coil packs.
NV is just way too hot no matter what you do.
You could try to improve airflow to it, you could try to install a custom heat shield.
Tons of people have tried various things before.
https://www.ft86club.com/forums/show...=30879&page=34
Old 06-24-2021, 08:57 AM   #22
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Did you run the smoke test. Vacuum leaks can cause weird symptoms. Ask me how I know.
Old 06-24-2021, 02:35 PM   #23
SexyPirates
I was reading a carbible about FRS today and it mentioned that to remedy coil pack problems some owners had the wiring harnesses replaced under warranty
Old 06-26-2021, 12:19 AM   #24
jflogerzi
jflogerzi's Avatar
He is way past that. Its not cheap as you need to get 4 new coils and upgrade to the new wire harness from the late 2015's
dip, engine, misfire, torque
Engine RPM "Hiccup"/Hesitation during initial acceleration OwlDance Issues | Warranty | Recalls / TSB 22 12-28-2019 09:48 PM
Sudden lean 17AFR, but then sudden rich 10AFR??? No codes D-VO Software Tuning 4 12-11-2019 12:17 AM
FS: CA BRZ stock wheels / tires 5500 miles BRZ-y Wheels and Tires 2 06-19-2016 05:58 AM
FS: KW ClubSport 3-Way Coilover Suspension System - $4750 (MSRP: $5500) ZeroTo86 Brakes, Suspension, Chassis 1 04-28-2016 11:46 PM
KW V3 coil over hiccup. Any suggestions? HillCountryGuru Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 04-03-2013 07:53 PM
