Old 08-10-2021, 10:06 PM   #15
skidz
Drives: 2017 GT86
This is great! I got the same controls and just double taped them to the steering wheel. Works but nothing as clean as this. Makes me want to get a 3D printer
Hope you'll upload the final model to thingsverse.
Good luck!
skidz is offline   Reply With Quote
Old 08-27-2021, 12:57 PM   #16
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
The AliExpress SWC buttons work using a resistance ladder. Each button correlates to a particular resistance between Key1/Key2 and ground.
An Arduino was utilized to read the resistance by using a voltage divider circuit. To do the prototyping, I used an Arduino Uno.
My Kenwood head unit reads SWC commands in a NEC IR format. Luckly, there a bit of information on how this works and some existing coding on the internet. I spent about a week troubleshooting the voltage divider and NEC IR code. Also added more functions by utilizing a "press and hold" feature to each button. Once that was done, I moved everything onto a smaller Arduino nano.
Obviously have to use the 3D printer whenever I can.
Here is the completed project. It is all working great and it feels super rewarding to do something novel like this.
projek_01 is offline   Reply With Quote
The Following 2 Users Say Thank You to projek_01 For This Useful Post:
brandonblt2 (08-28-2021), spike021 (08-28-2021)
Old 09-10-2022, 03:27 AM   #17
killy
Drives: BRZ Limited
Hello!
does anybody have the 3d file to share? I would really like to print one for mine.
thank you bery much
killy is offline   Reply With Quote
Old 11-08-2023, 11:00 PM   #18
ffh2303
Drives: BRZ 2013
Originally Posted by projek_01 View Post
After endless failed prints, weak tabs, tweaks and different brands of filament. I think I am finally content enough with this one.
Hi, can you share the files? It looks great, OEM+ even and I would like to get this done on my car as well. Thanks.
ffh2303 is offline   Reply With Quote
Old 12-31-2023, 11:58 PM   #19
Alexr
Alexr's Avatar
Drives: 2013 Hot Lava Scion Fr-s
This is actually a brilliant idea with it not looking too out of place. I know some people took the wireless controller like you found but just taped it onto their steering wheel and it looked very tacky. Some people did figure out how to retrofit a 2016+ steering wheel with controls onto a 2013 model but it required a lot more work. You should write this up in the DIY section.
Alexr is offline   Reply With Quote
Retaining steering wheel controls w/ aftermarket steering wheel on +17 BRZ/86 DDavid Electronics | Audio | NAV | Infotainment 8 04-22-2021 05:37 AM
More Steering wheel controls Jussy Electronics | Audio | NAV | Infotainment 12 03-22-2019 01:51 AM
steering wheel controls inimitable BRZ First-Gen (2012+) -- General Topics 79 09-05-2016 12:56 AM
steering wheel controls kaluce Electronics | Audio | NAV | Infotainment 5 01-29-2015 04:51 PM
Steering Wheel Controls theredtape Electronics | Audio | NAV | Infotainment 6 11-21-2012 09:59 AM
