08-05-2021, 02:58 PM | #15 |
TRACKBREAD
08-05-2021, 03:04 PM | #16 |
Drives: '23 BRZ
I don't have numbers in front of me, but my understanding was the PP brembos are heavier vs. standard non-PP brakes. For sure the rotors are. I swapped out my 23 lb. stock PP front rotors for 17 lb. Girodisc 2-piece. That was a lotta $$ per pound saved...
08-05-2021, 03:27 PM | #17 |
Drives: 2019 MX-5 RF
at the time i bought them, people on here said you save weight and gain better braking. i guess that information shifted. Is there any lighter + 4 piston very good heat dissipating systems that arent too expensive? 4 piston front 2 back.
08-05-2021, 03:44 PM | #18 |
Drives: 2022 GR86
One of the biggest benefits of a BBK is the added weight of the rotor, and thus thermal capacity.
Once the rotor has enough thermal capacity, the more expensive kits do weight savings by using lighter hats. Same with calipers/pads. I don't know about base FT86 pads, but on ND Miatas the Brembos have significantly bigger pads than base brakes. Or "Little Big Brake Kit", God forbid. Admittedly, you need to be driving pretty hard (e.g. at the track) for all that to make a difference. The biggest benefit of the PP on '17-'20 BRZ was the amazing value-for-money on those Brembos. And better dampers were included?! Sure, you can get a better aftermarket BBK, but it will probably set you back double or event triple the amount you'd pay for the PP option. One of the components here is that if you're buying base brakes you still have to pay for them, even if you're not going to use them. And there's not much demand on the second-hand market to buy those base brakes from you. And for sure Brembos look way better |
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | WolfpackS2k (09-03-2021), ~el~jefe~ (08-05-2021) |
08-05-2021, 03:50 PM | #19 |
Drives: Subaru BRZ
If anything, PP Brembos make changing brake pads a breeze. No more unbolting calipers and fucking around with a spreader tool.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
08-05-2021, 03:52 PM | #20 |
Rice King
I was going to say this, but figured it may not be worth the effort. Good thing you've got patience enough for the two of us.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
The Following 3 Users Say Thank You to Jordanwolf For This Useful Post: |
08-05-2021, 03:58 PM | #21 |
Drives: '23 BRZ
That was my #1 reason. *Hate* swapping pads on sliding calipers and having to use that little cube-tool to screw the rear piston back in...
08-05-2021, 04:01 PM | #22 |
Drives: 2022 GR86
You guys change pads?
The Following User Says Thank You to timurrrr For This Useful Post: | Yoshoobaroo (08-05-2021) |
08-05-2021, 04:33 PM | #25 |
Rice King
What relation does 200 hp have to Brembos?
Glorious Honda.
08-05-2021, 04:43 PM | #26 |
Drives: '23 BRZ
At the track, a lot... How much energy you have to dissipate in the braking zone is directly related to how fast you're going, which is directly related to how much power you have. More power = faster = more energy for the brakes to take and reject as heat.
I got a chuckle out of it when they added the big Brembos as an option. After years and years of "could use more power", they give it massive brakes sized for 300+ hp, and +5hp... |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | Blighty (09-08-2021), WolfpackS2k (09-03-2021) |
08-05-2021, 04:47 PM | #27 |
Drives: 2022 GR86
The Following 5 Users Say Thank You to timurrrr For This Useful Post: | Jdmjunkie (08-06-2021), Jordanwolf (08-05-2021), Stephen W. (08-07-2021), weederr33 (08-05-2021), WolfpackS2k (09-03-2021) |
08-05-2021, 05:03 PM | #28 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'm just mad I can't see my pads! Every car I've ever had, you can see them!!
The Following 6 Users Say Thank You to weederr33 For This Useful Post: | Jdmjunkie (08-06-2021), ng-86 (08-06-2021), NoHaveMSG (08-05-2021), Ultramaroon (08-08-2021), WolfpackS2k (09-03-2021), Yoshoobaroo (08-05-2021) |
Similar Threads | ||||
Black Brembos or Red Brembos? | Mike_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 04-30-2021 11:44 PM |
Other Enthusiasts Suck | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 23 | 06-01-2018 07:15 PM |
American Drivers Suck | ogrowup | Other Vehicles & General Automotive Discussions | 144 | 07-11-2016 10:30 AM |
All my LED's installed, they suck. | Yruyur | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 04-14-2013 07:23 PM |
well this may suck. | Mikes86 | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 12-29-2012 02:35 PM |
