Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-15-2021, 12:01 AM | #15 |
09-15-2021, 12:43 AM | #16 |
I suggest you bleed the hydrolytic clutch system. Maybe there is air in the system that is causing the clutch to act up -
09-15-2021, 01:02 PM | #17 |
Drives: car
@eman11500 any FR-S over 100k miles, get your transmission mount replaced or get the whiteline insert, as part of a "positive shift kit". Also consider getting the "positive traction kit" to fix drivetrain slop.
Also have you replaced the clutch throw-out bearing for the newer part? |
09-15-2021, 01:50 PM | #18 | |
As for a newer TOB, unfortunately I neglected to tell the mechanic to order an additional 17+ bearing for the kit when it was installed. This was before I really knew how much of a difference it would've made. |
09-15-2021, 01:52 PM | #19 |
09-15-2021, 03:16 PM | #20 |
Drives: 2013 WRB BRZ
Seems like you're bogging the engine. I usually try to keep revs between 2-3000 rpm when slipping the clutch. Only when I let it drop to 1200, like you showed, does it shudder/bog.
09-15-2021, 03:21 PM | #21 | |
Drives: 17 Asphalt 86
I have the white line insert and that takes care of 95% of the slop with very little NVH introduced. It's about a 15 min install if you use a jack on the trans to slide the insert in. Between that and the Mtec shift springs was probably the two best bang for buck mods I've done to the car. |
09-15-2021, 04:29 PM | #22 |
chicken tonight
Just popping in here. There is definitely something unsavory going on. Don't throw mods at it. This is either a sloppy driveline issue, or there's something wrong with the actual clutch.
I'm leaning hard toward clutch chatter. Stock clutch should easily slip to the point of overheating without chatter. I've taught a couple folks how to drive stick on my car. It doesn't take much to get it hot and still, zero chatter. Try a quick bleed. Just one squeeze. If you don't immediately get crackly air bubbles, move on. I think something is wrong with the friction disc.
The Following User Says Thank You to Ultramaroon For This Useful Post: | BrahmaBull1990 (09-23-2021) |
09-15-2021, 08:55 PM | #23 | |
ProCrastinationConsultant
i'm wondering if it's just like 'warped brake rotors' where some clutch material from the old clutch disc is transferred to the flywheel, and now it's resulting in unevenness in the surface of the flywheel
09-15-2021, 10:23 PM | #24 | |
chicken tonight
Ooo... Slip the clutch hard but finish by disengaging and idling until it has had a chance to cool?
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (09-15-2021) |
09-15-2021, 11:51 PM | #25 | |
09-15-2021, 11:52 PM | #26 |
part of me wonders if the OP is too nice to his cars and this is a result of not enough of an 'italian tuneup'
sometimes, ya just gotta thrash it!
The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (09-15-2021) |
09-16-2021, 12:31 AM | #27 | |
chicken tonight
CLUTCH: CLUTCH SYSTEM: DETAILS; 2013 MY FR-S [03/2012 - ]
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (09-16-2021) |
09-20-2021, 07:54 PM | #28 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Sounds exactly like my issue after my SC install. Mine was worse on hot days after driving 20 miles or so. I had the shift bushing and trans insert already. I had more than one thing done with my clutch install, but it came on after the whitleline trans insert.
I put three whiteline bushing kits in since. Subframe, read diff connection and diff mount bushings. I stll get it, but no where near as bad or often. I'd go for the rear diff connections bushings first, then subframe kit. I can feel it's from the rear diff bit, the kit stiffens it, but the frequency is still the same when I get it, albeit much rarer now and it holds it to smaller deflections. I was told clutch chatter at the start too, that's not it. |
The Following 2 Users Say Thank You to jeepmor For This Useful Post: | eman11500 (09-21-2021), soundman98 (09-20-2021) |
Tags |
shuttering, transmission |
Similar Threads | ||||
Car shuttering when starting it up | FRSNewb | Issues | Warranty | Recalls / TSB | 4 | 11-10-2020 08:43 AM |
QQQQBall's "RE"Build FR-S Thread (PIC HEAVY) | qqqqball | Member's Car Journals | 47 | 08-22-2016 08:30 PM |
SWP BRZ ("Stance" to Autox) Pic Heavy | BRZach | Member's Car Journals | 10 | 02-09-2016 06:35 PM |
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 12:08 AM |
Steering wheel/dash "rattle?" upon heavy acceleration? | brett_g | Issues | Warranty | Recalls / TSB | 2 | 08-04-2012 04:52 AM |
