Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 11-12-2021, 06:24 PM   #15
86-75309
Drives: Until recently, a 2020 Hakone 86
From torquenews.com:
"Subaru uses a form of the Subaru Global Platform but says the sports coupe couldn't share the same frame as a mass-produced car. The BRZ achieves optimum weight distribution of 53:47 with two people on board. They replaced the old hood and roof to make this happen."
So the key to proper weight distribution is to always have a passenger with you?
86-75309 is offline   Reply With Quote
The Following User Says Thank You to 86-75309 For This Useful Post:
Jucostud (11-12-2021)
Old 11-12-2021, 06:30 PM   #16
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Better put them in the trunk!
timurrrr is offline   Reply With Quote
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Jucostud (11-12-2021), ZDan (11-13-2021)
Old 11-12-2021, 09:35 PM   #17
Strat_FRS
Drives: 2015 FRS for daily and track use
Will be getting ours this weekend. Can't wait to get it on the dyno back to back with our 2015 FRS (which is modded).
Strat_FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to Strat_FRS For This Useful Post:
boy_racer (11-13-2021), Simmons (11-12-2021)
Old 11-13-2021, 01:57 AM   #18
WC-BRZ
Drives: Black BRZ
I honestly cannot wait till someone starts a weight loss thread with these...
...nothing too crazy like Anthony's weight loss build with his FR-S, but seeing these down to 2500lbs would be SO COOL!
WC-BRZ is offline   Reply With Quote
The Following User Says Thank You to WC-BRZ For This Useful Post:
Simmons (11-13-2021)
Old 11-13-2021, 07:00 AM   #19
AgentBlue243
Drives: 2022 WRB BRZ limited
I always wondered how a build with Anthony’s weight loss and @celek’s theoretical fa23 engine would go, but sadly both of them couldn’t see the light of day.
AgentBlue243 is offline   Reply With Quote
Old 11-13-2021, 07:40 AM   #20
Simmons
Simmons's Avatar
Drives: 2022 BRZ
I am wondering where the extra weight is on these over the 1st gen. I had my 13 Brz down to 2,555lbs in STX trim.
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 11-13-2021, 08:12 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
As suggested above, put passenger in the trunk! Under the spare tire!
53:47 is *far* from "optimum" for an FR sports/sporty car, and they couldn't even achieve that.
Weight distribution is the same 55F/45R as the last-gen. Not great...
Old 11-13-2021, 08:13 AM   #22
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
Originally Posted by ZDan View Post
I already do that to meet weight for my time trials class! Sometimes add a stock front brake rotor on top of the spare! Still no better than ~53.5/46.5 even with 5 lb. battery, 12-lb. lighter front rotors, empty washer reservoir, and catless header (-50 lb. off the nose of the car).
Are you weighing it with you sitting in the driver's seat? I'm guessing the driver's weight gets added mostly to the rear.
PhatFreshPrince is offline   Reply With Quote
Old 11-13-2021, 08:24 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yes, weight with me in the driver's seat. If the rear wheels were where they should be, right behind the front seats, driver weight would be mostly on the rear wheels. As it is, with rear wheels shoved way aft, driver weight is ~45F/55R...
Rcode (11-13-2021)
Old 11-13-2021, 09:27 AM   #24
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Who was expecting a significant difference?
This car is almost exactly the same as the old one. Overall weight changed by less than 1.5%. Even going from 55/45 to 53/47 is probably with both seats all the way back, no washer fluid, and all the shit from the glove compartment in the trunk.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 11-14-2021, 09:19 AM   #25
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Increasing the body rigidity, strengthening the drivetrain as well as adding "modern" equipment tends to increase the weight. They tried to keep the overall increase low, but they are fatter no matter what. Here is some detailed information of the factory savings:
Aluminum front fender: -3.0kg
Aluminum front housing: -3.0 kg
Aluminum roof panel: -2.0 kg
Hollowing of front stabilizer: -0.5kg
Weight reduction of muffler: -1.6 kg
Weight reduction of front seats: -2.6 kg
Weight reduction of propeller shaft: -1.1 kg
Front to rear weight distribution is almost the same. Not that much of a difference. There were also voices going into a turbo setup, but then front weight would be much more and cornering performance worse. Price would be higher too.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Jianlun (03-09-2023), Simmons (11-14-2021)
Old 11-14-2021, 01:57 PM   #26
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Seems to be some conflicting information on if headers swap or not. My understanding was it's a different size so headers aren't swappable but there are people in here saying theirs swapped? What's the consensus?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
cactus (11-28-2021)
Old 11-21-2021, 05:16 PM   #27
GoodToBeKing
GoodToBeKing's Avatar
Drives: 2019 Tundra TRD SPORT
Interesting OP...thanks for posting.
GoodToBeKing is offline   Reply With Quote
The Following User Says Thank You to GoodToBeKing For This Useful Post:
Jucostud (11-22-2021)
Old 03-07-2023, 04:34 PM   #28
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
Adding a donut spare tire brings the weight distribution closer to 50/50.
Mcgiiver is offline   Reply With Quote
Corner Scales? Campo Arizona 1 02-14-2022 04:58 AM
Vorshlag BRZ/FR-S/86 Camber Plates for KW v3 AWE46M3 Brakes, Suspension, Chassis 0 06-24-2020 08:58 AM
OFT - Example alternate maps for AT, 98RON, E85, MAF Scales Wayno Software Tuning 562 06-24-2017 04:36 AM
Vorshlag LSX kit cf6mech Engine Swaps 749 12-06-2016 04:21 PM
any one sell vorshlag?! FISHBURGLAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-20-2015 01:49 PM
