12-22-2021, 10:38 PM | #15 |
Drives: '22 BRZ
I've had a speaker rattle on the drivers side since the car rolled off the lot first week of November. No other issues.
12-22-2021, 11:12 PM | #16 | |
Drives: 2015 FRS for daily and track use
It's no the cat, it's the motor itself. When you let off and it coasts down in high RPMs there is a rather harsh rattle/resonance. |
The Following User Says Thank You to Strat_FRS For This Useful Post: | ForeverCar (12-22-2021) |
12-22-2021, 11:32 PM | #17 |
Drives: 2022 BRZ and some other cars
12-23-2021, 12:10 AM | #18 |
Drives: IS300, WRX, STI, Bicycle
Interested to know more about the mirror issue. Anyone know where the harness is, is it a bad mirror, or the short harness between the mirror/dome area? Hoping it's not a long harness going all around the car.
12-23-2021, 06:12 AM | #19 | |
Drives: 22 BRZ Limited
Per Kado's post (https://www.ft86club.com/forums/show...04&postcount=2) it's a bad harness. I installed a homelink mirror myself, and have the same issue. There's wiring that's run around the vehicle up to the dome console. With the mirror kit, you get an additional 3 wire harness/adapter you plug into that and run down to the mirror. That adapter goes from 3 to either 8 or 10 pins at the mirror... I'm guessing they just don't have one of the 8 or 10 mirror pins mapped to power for the homelink lead. |
12-23-2021, 07:53 AM | #20 | |
Drives: 2022 BRZ Limited SBP
12-23-2021, 10:10 AM | #21 | |
TRACKBREAD
The patch harness is bad, the car is providing power/ignition/ground, that’s enough. The patch harness doesn’t have the HL connected to the ignition looks like. |
12-23-2021, 10:59 AM | #22 |
Drives: 2022 BRZ
And I thought I was crazy with the blinker issue..
12-23-2021, 11:28 AM | #23 | |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Not complaining but just observing. |
12-23-2021, 03:50 PM | #24 | |
Drives: Ford Fiesta ST, 2022 Subaru BRZ
Unplugging the phone for a minute or two sometimes remedies the problem, but not always. It's odd that it works fine in my parent's Crosstrek. The only other issue I have is that the blind spot monitoring doesn't beep when a car is beside me and the blinker is on. The settings indicate the beep is on, but nothing. The shift beep does work though. Don't know if I'm missing something though. Otherwise, and knock on wood, the car is solid. I haven't noticed any blinker issues yet. |
12-23-2021, 10:28 PM | #26 |
Drives: 2022 BRZ WRB
This is a great thread, thank you everyone for contributing.
12-24-2021, 02:50 AM | #27 |
Drives: Subaru BRZ
"Them crickets,them crickets, them crickets, they were banished from the series 1 only to haunt the series 2"..
12-24-2021, 02:51 AM | #28 |
Drives: Subaru BRZ
Similar Threads | ||||
Anyone not buying to avoid early issues like 1st gen FRS? | stocktc1 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 203 | 09-23-2021 09:11 PM |
Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) -- General Topics | 34 | 02-27-2019 08:56 PM |
New 2014s still have early issues? Prospective buyer | Lord09 | Issues | Warranty | Recalls / TSB | 25 | 06-14-2014 04:42 AM |
Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 04:39 PM |
Initial Issues / Problems | JDMSushi | AUSTRALIA | 56 | 09-30-2012 10:21 PM |
