Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-23-2022, 05:45 PM | #15 |
Drives: '23 BRZ
IMO bump travel is the first concern. Me, I lowered my '17 BRZ 1.5" and don't worry about camber etc. I do have Bilsteins, which have a lot more front travel than stock PP/Sachs struts.
01-23-2022, 09:44 PM | #16 |
Drives: 2013 frs base
Pretend I don't know much about suspensions. I'm guessing by "bump travel" you mean how far the suspension goes before bottoming out? A buddy has a lightly used set of Tein Z that I am looking at. I'd like to lower my car only about an inch.
01-23-2022, 10:18 PM | #17 |
Drives: '23 BRZ
Shouldn't be any problem with Tein Flex Z coilovers. It's the stock front struts that have limited bump travel, any decent aftermarket coilovers will be OK with over 1" lowering.
The Following User Says Thank You to ZDan For This Useful Post: | blsfrs (01-24-2022) |
01-24-2022, 11:29 AM | #18 |
Drives: Crapcan
I ran Flex Z's for a bit and spent some time on track with them. They don't like being lower than -1.5 from stock. I ran -1.25 from stock and they handled that pretty well, trucking curbs at speed and everything.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (01-24-2022) |
01-25-2022, 04:44 AM | #19 | |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
WedsSport TC105X 18x8.5 +43 weighs only 16.4 lbs! It's one of the lightest, if not the lightest, wheel I've found so far in that size category even against forged ones.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
01-25-2022, 11:33 AM | #20 |
Drives: Crapcan
Yes, I am aware there are outliers. 949 found more performance by going to an 18". Speaking in general with most wheels on the market, it is not the best. +43 offset is yuck though, I have enough clearance issues already.
01-25-2022, 11:48 AM | #21 |
18x8 is just fine with a quality wheel. I'd also reccomend a 225 instead of the 245 since it's a better fit for the 8 inch wide wheel.
Lowering springs do work well especially those that have a more mild drop. But if you're 2014 stock struts have a lot of miles on them...it would be worth considering swapping those out for Bilstein B6. No need for diff risers unless you're slammed. - Andrew |
01-25-2022, 12:20 PM | #22 |
My 14 was almost 2 inches on RSR Superdown lowering springs. Nothing else special done. 150,000 miles with zero issues.
01-25-2022, 01:02 PM | #23 |
Drives: 2014 FR-S
You didn't end up blowing the stock struts on superdowns? I had to upgrade to Bilstein B8s to compensate for that low of a drop.
Professional Car Breaker
01-25-2022, 01:29 PM | #24 |
Nope. The guy that bought it swapped everything out to track but all was still good.
The Following User Says Thank You to Tcoat For This Useful Post: | rbfr.s (01-25-2022) |
Tags |
coilovers, wheels and tires |
Similar Threads | ||||
WTB: STX Suspension (Coilovers) and Wheels+Tires | Optimoose20 | Want-To-Buy Requests | 0 | 08-25-2020 03:56 PM |
FS: Stock 2012 FR-S wheels/tires and Enkei PF01 Winter Wheels/Tires - Lexington KY | deljaso | Wheels and Tires | 3 | 04-22-2020 08:33 PM |
Remove P4S tires from my stock BRZ PP wheels and mounting snow tires? | jredders | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 10-25-2019 11:30 PM |
BC Coilovers installed-Stock Wheels/Tires | continuecrushing | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2016 06:32 PM |
