NY / NJ / CT / PA NY, NJ, CT, PA |
05-02-2022, 11:45 AM | #15 | |
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
But I still stand by my statement. Subaru Motor, Subaru Tech. Not taking mine to Toyota. But I’m also not going too have the recall performed unless my state decides to make me do it in order to register. Which is unlikely. I don’t have emissions here in Washington. To each their own. |
The Following User Says Thank You to Sur For This Useful Post: | Dadhawk (05-02-2022) |
05-02-2022, 02:08 PM | #16 | |
Drives: 2018 Subaru BRZ
I let a Subaru mechanic touch my fuel pump recall (2018+) which ended up costing me a walk to the gas station because the fuel gauge stopped working properly, which hence caused me to run out of gas even when the indication was a 1/2 tank. Then had to empty out a full tank of gas because the same tech put 89 gas on a car that is tuned for 93, that was fun. Then had to proceed and clean out the car because the tech left the back full of boot marks and foam from the back seat. Their excuse, over whatever amount of years that dealership has been in service, they have never worked on a BRZ. |
The Following 2 Users Say Thank You to spcmafia For This Useful Post: | soundman98 (05-02-2022), Ultramaroon (05-02-2022) |
05-02-2022, 02:11 PM | #17 |
Drives: 2017 BRZ w/PP
i took mine in for an oil leak on the head under warranty and a rocker exited my block 400 miles later and i pulled rtv out of the pickup. also they rtved in my hpfp for some reason so that went in the fuckitbucket too. just drive it until it breaks and replace it then.
The Following User Says Thank You to Breadman For This Useful Post: | Ultramaroon (05-02-2022) |
05-02-2022, 09:08 PM | #18 | |
1st86 Driver!
As far as who does the work, there were failures on both sides, and not nearly a high percentage as it "feels like" from reading this forum. The mechanics all received training on this specific repair, and they had to be of a certain skill level. If you do have to have it done, ask questions, and you should get a good result. By the way, unless you pay for it out of pocket, Subaru won't do the repair on a Toyota as they won't get reimbursed for it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | bcj (05-03-2022) |
05-03-2022, 12:38 AM | #19 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I had the surgery done at 90k miles mostly because it was free and I had just heard the beginnings of the terminal throwout bearing.
Surprised it lasted that long. No damage, but got that fixed with the new version for a price. It was an engine out operation so the clutch is sitting right there in the meantime. That was sometime last winter and I hadn't really put any sort of mileage in with mostly nowhere to go to and a gamey knee. It has had regular trips to the grocery so it's been abused with short trips. Time to blow the dust out. Just got back from a road trip to Cannon Beach Or. and the car has performed fine as it hasn't caught fire or blown up, yet. I've been keeping an eye on it, and there are no detectable oil leaks so far. Was also one that didn't have leaks to begin with. Happy with the value so far, and hope it will run a few more miles. non-seq. -- New windshield wipers are a significantly appreciable upgrade.
"I gotta rock." -- Charley Brown |
The Following 2 Users Say Thank You to bcj For This Useful Post: | Dadhawk (05-03-2022), Ultramaroon (05-03-2022) |
11-02-2023, 05:40 PM | #20 | |
Drives: 2013 Fire Storm FR-S
I was checking in to see if a class action ever took off for this issue but I see this thread is over a year and a half old. |
Tags |
frs, recall, valve springs |
Similar Threads | ||||
Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 05:24 PM |
BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
