go_a_way1
Old 08-21-2012, 09:34 PM   #15
APS86
Drives: GTS86 Manual
Hi ya,
Thanks for starting such an awesome thread ..... have been trying to work this out for some time now.
Plan is TRD coilovers leaving at the standard 15mm drop then on the front 18x7.5 +38 and rear 18x8.5 +30 wrapped in 235x35 tyres (I think as that gives only a slight speedo difference) - will this fit and be flush?????
huge thanks
APS86 is offline   Reply With Quote
The Following User Says Thank You to APS86 For This Useful Post:
nextcar (02-15-2017)
Old 08-21-2012, 10:14 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by APS86 View Post
Hi ya,
huge thanks
Rear would be pretty flush, fronts might could use a spacer of about 8-10mm.
JoeBoxer is offline   Reply With Quote
Old 08-21-2012, 10:29 PM   #17
APS86
Awesome - thanks so much for that information
Old 08-21-2012, 10:56 PM   #18
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by JoeBoxer View Post
+32 would be 6mm poke if +38 is flush, not 6mm sunken.
Need to address this typo first. +32 is indeed 6mm further OUT from +38.
ill86 is offline   Reply With Quote
Old 08-23-2012, 11:16 AM   #19
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
If the goal is flushness, is stretching tires on a wheel required? I thought the fenders come pre-rolled.
The question stems from observation and this thread http://www.ft86club.com/forums/showthread.php?t=15323
F1point4 is offline   Reply With Quote
Old 08-23-2012, 11:23 AM   #20
JoeBoxer
JoeBoxer's Avatar
Depends on how low you want to go I think, you can run stock height or 1" drop without stretched but if you want to go lower or run lower offset/wider wheels you will need to stretch.
Old 08-23-2012, 11:28 AM   #21
F1point4
Photo Specialist
F1point4's Avatar
Oh yes, I forgot to mention stock height. Although it will look off, I'm not ready to mess with the suspension geometry yet. Thanks for the info.
Old 08-23-2012, 11:36 AM   #22
JoeBoxer
JoeBoxer's Avatar
Are you looking at those same wheels or something else?
Old 08-23-2012, 12:04 PM   #23
Thobjo
Drives: GT86
Would 16"x6.5" ET53 or 55 offset work for winter tires?
Rather not spend money on winter wheels at all but need to be able to move the car in and out of garage even in snow.
These are the original 2002 Impreza and Impreza WRX wheels.
Thobjo is offline   Reply With Quote
Old 08-23-2012, 03:38 PM   #24
DC-FRS
Im looking to get the Work Emotion Kiwami deep concave all the way around. The only size they make them in is 18x9.5 with a +30 offset. Would this work with stock height? I dont want to rub or anything like that, obviously. Also would I need different tires for them? What would be the best tire size for them? Also, what kind of poke/sink look would I be getting with these? Thanks for any questions answered. I appreciate it a lot!
DC-FRS is offline   Reply With Quote
Old 08-24-2012, 11:01 AM   #25
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
http://www.ft86club.com/forums/showthread.php?t=11258
Gonna need coilovers to pull it off or you'll be poking by 3/8"-1/2" would be my guess.
digital_assassin is offline   Reply With Quote
Old 08-24-2012, 12:01 PM   #26
ill86
ill86's Avatar
Drives: iG FR-S
He doesn't need coilovers.. Springs and an alignment would work fine.
9.5 is a lot of wheel though. Could run a 235-255mm tire.. Def aggressive fitment.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
Old 08-24-2012, 02:18 PM   #27
digital_assassin
Suppose I should have said drop and camber :wink:
Old 08-25-2012, 04:43 AM   #28
w arghh x
[I 86 I]
w arghh x's Avatar
Drives: Toyota 86 GT
Im pretty confused with all this offset stuff
18x8 with a +42 offset. Will this be fine? 225/40/18 tires also....
w arghh x is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
