BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
07-12-2022, 01:45 PM | #15 |
Drives: ‘13 AT FRS
Oh NOW a tldr is acceptable to Snuff. Assuming that is meant as irony so I won’t answer.
07-12-2022, 02:09 PM | #16 |
Drives: X5 35d, D90, CX-5 Turbo
07-12-2022, 02:35 PM | #17 |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Ogt (07-12-2022), OkieSnuffBox (07-12-2022) |
07-12-2022, 03:17 PM | #18 | |
Drives: '23 BRZ Limited
It doesn't take nearly 15 minutes to show two dyno pulls. I don't understand why wanting objective evidence is so offensive to some.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Tcoat (07-12-2022) |
07-12-2022, 03:52 PM | #19 |
Drives: ‘13 AT FRS
The evidence is there if you want it, not my job to convince you.
07-12-2022, 04:13 PM | #20 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Everywhere I've read so far, nobody's found a way to tune the ECU (maybe I'm wrong, hopefully I'm wrong). I've also heard about YouTubers' cars not running very well off camera. Will I remove the tissue from the car's nostrils? ehh... I need a larger sample size before I do it to my own car.
07-12-2022, 04:30 PM | #21 |
Drives: ‘13 AT FRS
There’s probably a chance if you had engine issues, Subaru could deny fault over it. Personal decision to be made there.
I would assume the YouTubers issues are associated more with running full catless exhausts without a tune over a slight increase in airflow. Edit: do consider according to previous post, the JDM version does not include the pad at all from factory. Another thing to consider is if you go buy whatever aftermarket intake at $300+ that may claim 7hp increase; 5 of that could be coming from the effective removal of this. Maybe making it not worth time or money to some. |
The Following User Says Thank You to Ogt For This Useful Post: | mike2100 (07-13-2022) |
07-12-2022, 07:13 PM | #22 | |
Drives: 2022 BRZ
They've posted on the other forum that shall not be named. Sent from my Pixel 6 using Tapatalk |
The Following User Says Thank You to patsimca For This Useful Post: | mike2100 (07-13-2022) |
07-13-2022, 10:06 AM | #23 | |
The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | Ogt (07-13-2022) |
07-13-2022, 04:50 PM | #24 | |
Drives: zd8 brz
unless you get caught with a state referee ticket, youre safe for 8 years. even if you do get caught with a state referee ticket, you can purchase the half airbox piece for like $65 last i checked. shove it in the corner of your garage until the day you need to smog it, and toss it on at that point. as far as performance and the car running poorly. I ripped mine out and it's been driving perfectly fine. Youre gonna get issues from people who are running UEL headers.. something the car/ECM was absolutely not designed to run with by any means. Hell some people are even running small amounts of e85 for god knows what reason. |
The Following User Says Thank You to mycrors7 For This Useful Post: | Ogt (07-13-2022) |
07-13-2022, 10:54 PM | #25 |
Drives: "I drives like a Porsche"
If I remove this will void my warranty and while I still pass emission in California?
07-13-2022, 11:53 PM | #26 | |
Drives: zd8 brz
it wont pass california visual inspection during smog(assuming the smog tech actually checks) |
The Following User Says Thank You to mycrors7 For This Useful Post: | Tcoat (07-14-2022) |
07-14-2022, 07:19 AM | #28 | |
Doubt there is really 10hp to be had but may get a couple out of it. Not going to "void" any warranty unless they can prove that having it there caused the issue. Be pretty tough sell on their part. Won't need a tune and it won't cause the engine to run poorly. It just isn't a big enough change to have that much affect. Same as using any aftermarket drop in. Of course a tune will make things "better" but you could likely get the same results from tuning with it in place. Stock tunes are never the best since they need to compromise for fuel economy and emissions. This whole thing is much ado about nothing really.
The Following User Says Thank You to Tcoat For This Useful Post: | OkieSnuffBox (07-15-2022) |
Similar Threads | ||||
My First Run Impressions and Testing Results with (knockoff) Billet Power Blocks | Tatsu333 | Engine, Exhaust, Transmission | 9 | 09-16-2022 06:43 PM |
ACE Header Independent Testing Results and Review - 199.6WHP on CA 91 Octane | CounterSpace Garage | Engine, Exhaust, Transmission | 849 | 08-26-2020 04:44 AM |
Objective CLD (sound deadening) Testing Results | TOOSTUBBORN2FAIL | Electronics | Audio | NAV | Infotainment | 9 | 03-23-2016 06:41 PM |
Motor Oil Testing Results | Rocket.BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 06-30-2014 10:48 PM |
Air filter Testing | Fast_Freddy | Engine, Exhaust, Transmission | 0 | 06-06-2013 01:21 AM |
